Results 1 to 10 of 28
Thread: 1KW PFC _ CCM Power Factor Corrector.
    Thumbs up 1KW PFC _ CCM Power Factor Corrector.
    First successful test of my 1KW PFC.
    Setup looks bad, But this is how it looks first time!
    Setup Information:-
    Topology:- CCM
    Input Voltage:- 107VAC
    Output Voltage (DC):- 382VDC
    Output Current (DC):- 2.9 AMP
    *Voltage Drop at 1000W Load is around 3 Volts.
    * Current Drawn from 107 V AC line is 10.4 AMP (AC) _ PFC Loaded
    * Using IGBT
    * Special costume Inductor used, 200C rating
    * IGBT Tempreture after 15 Minutes 58C with FAN.
    I noticed that the output diode affects the PFC performance, it heats like hell and causing the voltage to drop very quickly Until I found the correct one.
    Upcoming tests will be shown, when I have AC source of 90VAC + more tests at Higher Loads!
    Thanks for reading.
    however, Load BURNED after 42 Minutes of continuous operation
    very interesting
    I expect some parts to start testing
    my tests would be.
    85v input min
    260v max input
    390V 10 amp ouput.
    with L5661
    you use as a control FET.
    health will be pending. this issue.
    Quote Originally Posted by kanon View Post
    very interesting
    my tests would be.
    85v input min
    260v max input
    390V 10 amp ouput.
    with L5661
    hmmm
    390V DC Output @ 10AMP
    Thats lot of power indeed, 3900W from 85V AC. I wonder if you have the proper Inductors to do that kind of power at 85VAC.
    I am not using FET. I am using IGBT
    That looks wrong part number. L5661
    Good job mr. Microsim you're best switcher ı have ever seen now. I'm waiting use amplifier with smps
    Moderator DjLeco's Avatar
    Sep 2010
    Bucharest , Romania
    114
    To make an good PFC, need more aknowledgement.
    Tell us mr. kanon, wich inductor U will use for that amount of power?
    And what switching component?
    1700W PFC Test
    1700W Power Factor Corrector Testing.
    1700W drawn from the PFC. Heat is serious at this test.
    3kW?
    very interesting
    my tests would be.
    85v input min
    260v max input
    390V 10 amp ouput.
    with L5661
    That looks like another big Joke / Claim
    3KW from 85v AC? is that 3 phase PFC then?
    Microsim,
    Can you share the PFC inductor design?
    Quote Originally Posted by TBDz View Post
    Microsim,
    PFC inductor is just a 100uh Inductor with -8 Core material
    diysmps Senior Member vorezky04's Avatar
    Feb 2012
    Indonesia
    112
    where is it placed?
    I am from indonesia.
    I love peace
  1. Replies: 7
    Last Post: 12-10-2017, 07:18 AM
