Page 1 of 13 12311 ... LastLast
Results 1 to 10 of 125
Thread: "TO-247" First Project - 600W SMPS"
    Post "TO-247" First Project - 600W SMPS"
    Hi
    i'm going to start my first audio smps.i want use it for my Nmos200 :
    http://www.diysmps.com/forums/showth...2-Pair-Edition
    +/-40v 5A 2X200W@2Ohm - 600W max power consumption = +/-40v 7.5A per rail
    i was read this thread :
    http://www.diysmps.com/forums/showth...icrosiM-design)
    now i'm confused
    i don't know which circuit is suitable for me !
    IR2153 or IR2110+SG3525
    it's because at first , ludo built the ir2153 based circuit but in newer version , he was build 3525+2110 based circuit and result was more reliable.
    can anyone help me about this issues ?
    there is the latest version of Ludo's IR2110+SG3525 based circuit , please tell me about it , it's OK ?
    "DIYSMPS"
    DANGER ! HV AROUND , DEATH is PERMANENT
    Last version of ludo`s SMPS is working fine, and it will save you time
    If you decided to make it, post every step here, to save your time later
    My SMPS schematic is ready !
    it's Ver.0
    please download and tell me about it , what you think ? it's Good and reliable ?
    it's like Ludo's last design , but somethings changed.
    "DIYSMPS"
    Cool
    It looks Good
    Make sure to review it before making PCB. just to prevent any mistake.
    Other wise, very nice schematic!
    Thanks MicrosiM
    But i think that schematic have a lot of problems :
    - the output voltage not adjustable , what you think ?
    - the Snubber circuit behind the mosfets (5R6+330pf) , it's a copy from QSC PLX1802 Schematic ! it's ok for this circuit ? that circuit use IGBT and worked in resonant mode.
    - what about current sense inductor ? 15uh is ok ? please tell me about winding and core specs.
    - main transformer was calculated based on excel file and you can download 80V design on the attachment. i got minimum voltage of the 220v line around 200v , then 200v X 1.41= 282v/2 = 140v , you can see another parameters on excel file.
    - on current limit circuit , how much is the P1 ?
    - the output inductor maybe in wrong place , it's must be after the rectifier , also i don't know the good specs for that.
    I'm sorry for asking too meny questions
    "DIYSMPS"
    Thanks MicrosiM
    For audio application, you dont need regulated SMPS.
    Your snubbers are OK, whats the problem if you take info from other designs?
    Current sensor will be try and error at the first, that value is just OK as a start
    If you have followed the formula, your transformer will work.
    P1 value, start with 50K
    No need for those output inductors, since its not a REGULATED SMPS
    * Calculations for transformer is OK
    Dont forget
    Making this SMPS from scratch, like in your case, will need things to be done right
    I advice you to ask about every thing.
    Good Luck!
    Thanks for quick replay
    i think that design may not work good in my design , but it's good choice for me.
    the value of paralleled wires are ok ? the current of secondary is about 7.5A at maximum , 15X0.1mm will be ok ?
    Dont forget
    don't worry it's not my first 220v smps , i have made 100w 18v smps about 1 years ago , but design based on pi-expert.
    i'm also download very useful pdf files from this forum to learning about construction , winding , calculation and many other things , thank you for supporting "DIYSMPS"
    what's your opinion about 16v 0.5A auxiliary smps ? i want to design and replace it for pcb transformer.
    anyway , i think designing this PCB will be difficult
    i'm also going to buy Rigol 100mhz Scope and X100 Probe , also isolation transformer
    - the schematic at version 0.1 also available , but i'm not grantee the operation of this circuit before testing it.
    "DIYSMPS"
    1- The parallel wires are OK.
    2- 16v 0.5A auxiliary transformer is OK
    This circuit is already working, but SMPS needs a try before making the final design, ludo made 4 prototypes before the final version.
    How Can I Get +/-24v (For Eq,Protectors,Fans,Etc.) on this smps ?
    if the voltage per turn = 7.78 , then for 24v = 3Turn + 16v = 2Turn = 40v 5Turn
    is this schematic true ? can i use this method ?
    "DIYSMPS"
    Quote Originally Posted by TO-247 View Post
    Can anyone help me ?
    "DIYSMPS"
  1. 1kW smps project (based on MicrosiM design)
    By ludo3232 in forum diysmps
    Last Post: 11-12-2018, 07:59 AM
  2. 500W Smps project
    Last Post: 12-07-2015, 08:11 PM
  3. my 900w fullbridge smps project
    By erhan739 in forum diysmps
    Last Post: 12-18-2014, 03:24 PM
  4. 1 KW SMPS Project Discussion
  5. Open SMPS Project 1kW
    By Murilo in forum diysmps
    Last Post: 07-26-2011, 12:08 PM
