just be patient guys i get a hold of a camera and i will do the above
What is the limiting factor of this amp in running past 50V?
hi all just found this schema by detex audio seems simple . what makes it 100watts and not 200 watts?
I noticed that this 200w amp doesn't have an input cap... I want to put one, can I use a polarized one like in IRS900? or a non polar cap?
you refer to the simple amp posted by stewin above or another 200w amp? the one above have a 4.7uf 16v cap with 27kohm input impedance. you can use polarized cap but non-polar or film cap are usually more preferable. most design could be modified with increased input impedance which allow the input cap value to be reduced, allowing high quality film cap to be used.
norazmi i need help for my 3 pairs mosfet im using irfp250n i want to load at 2.6 or 2 ohms for high voltage at +/-98 vdc plz plz irfp250n can handle this specs that i wanted. coz i have here 70 0 70 ac trafo 12 amps i need your assistance sir...or wat mosfet that im going to use for compatible this kind of specs that i want.thank you
Hi Norazmi,
after reading all the pages on this article, I am tempted to go for this, being the electronics hobbyist I have had made several small circuits, though Techincally not into electronics but still, I can recognise all electronics parts. As it is I was Planning to make subwoofer amp. for personal use.
PravPa
for obtain best sonic of this amp, pls refer to original part, use irf530/9630 instead of irf540/9540. matching gate charge and Ciss are the first thing. you will get a very good sonic from low to high, comparable to any AB class. it will have unique sound character, almost like KN7*** keyboard series.
Glo
