Page 42 of 42 FirstFirst ... 1232404142
Results 411 to 420 of 420
Thread: IR2153 smps with short circuit protection.
  1. #411
    Quote Originally Posted by kinter View Post
    some picture of my pcb....
    is almost finished but there is not IR2153
    Attachment 4648Attachment 4649Attachment 4650Attachment 4650
    Hello!
    please answer. give a scheme & pcb...
  2. #412
    Oct 2011
    Kuala Lumpur, MY
    586
    im back
  3. #413
    hola michelle tienes el pdf de smps, lo puedes compartir gracias
  4. #414
    Oct 2011
    Kuala Lumpur, MY
    586
    i know some having problem with high voltage at output when using ir2153 because this chip dont have softstart, but we can solved it by make softstart circuit directly from 220 vac using few components and relay, ill post new picture soon, i have made new one but this time im ordering pcb lol from jlcpcb because its cheap, and i solved the peak startup of ir2153 and its running very smooth and smart, btw its 50% all the time duty cycle, if we want external aux we can use simple tny chip ie tny264 can maxed up to 300ma for 12vdc or we can get more current with tny268 with same circuit just change the chip, this chip has internal protection, overvoltage, overcurrent, short circuit, over temp, and i already terstg it ofc none of my tny burn and its very simple circuit also, so when i do this post means all thing has been ready setup and complete but i still have alot of pcb board because 1 order i get 10pcs, so i do setup with irs2153 v.out +- 67 vdc to pull 2 irs2092 rated at 250w 8 ohm, and irs2153 v.out 27vdc to pull tpa311d62 100w+100w, so all of them good with softstart, ill take picture and video soon here.
  5. #415
    Quote Originally Posted by norazmi View Post
    im back
    Welcome back! long time..
    www.diysmps.com & www.Micro-Audio.com
  6. #416
    Oct 2011
    Kuala Lumpur, MY
    586
    Quote Originally Posted by MicrosiM View Post
    Thanks my friend.
  7. #417
    Oct 2011
    Kuala Lumpur, MY
    586
    2 ir2153 smps, 1 running on btl tpa3116 d2 120w + 120w at 27vdc 20 amp, another one running +- 67vdc 15 amp, with softstart and protection, nothing to worried and its running hard .
    http://stg01.gcmaster.club/azmi/a.mp4
  8. #418
    Oct 2011
    Kuala Lumpur, MY
    586
  9. #419
    Oct 2011
    Kuala Lumpur, MY
    586
    i try youtube maybe ok lol
    https://youtu.be/tvZ9q53Cz-A
  10. #420
    Oct 2011
    Kuala Lumpur, MY
    586
    clear pic inside.
  1. Replies: 9
    Last Post: 04-08-2013, 12:03 PM
  2. Loudness control - circuit!
    By radio in forum Pre Amps
    Last Post: 09-29-2012, 06:53 AM
  3. active short-circuit breaker for your amplifiers
    By erhan739 in forum Class AB
    Last Post: 10-11-2010, 09:25 PM
