Full-bridge at +\- 50V 4Ohm will result in 25A load current 100\4=25
we get for EI33 22uH , 25A , 5mm gap , 21turn
Copper the twice
So is not meaningful to apply it in a half-bridge.
Copper the twice
Dimonis 1mm gaps will get core hot quickly, and what about coil size? proper coil size i needed to deliver enough current through it and decrease core being hot and stress too. This thing need to be experiment in real life will tell u everything![]()
hi dimonis hope you can share the English version of your software...
Dimonis, u can do simple translation by capture image and write into it![]()
Yo Stewin, any update of ur amp? My ucd now current hunger and when do parallel mosfet need more capacitor banks or the power supply will clips amd drop hard. Im now Working on short circuit protection OCP and i`ll make proper test with 60va 24 0 24 vac first after success i`ll test with smps at high current.
hi all here are my updates i'm working on the pcb will post pictures
Hi Stewin
greetings NICE WORK
warm regards
michelle
