Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Cheapest PRINTED CIRCUIT BOARDS starting with 0,0375 Euro / cm2.
    Hello everybody,
    I present you attached the cheapest manufacturing way, for SINGLE / DOUBLE pcb layer ( home made ) with semi-professional look , starting with 0,0375 Euro / cm2.
    As OPTIONAL : Tinning ( traces and pads ) , SILKSCREEN ( components mask )
    You can see also some more projects of mine to bellow address:
    https://www.dropbox.com/sh/gz4t8fdnt0ylfu3/Fia1FUt9Yu
    If someone ( without technical possibilities and required time ) need to build a prototype board or very small quantity ( up to 10 pcs / pcb ) , please feel free to contact me to : msdesignerpro@gmail.com
    I can deliver you all over the world , in cheapest way , through National postal mail services.
    Kind Regards,
    MSdesigner Pro
    E-mail: msdesignerpro@gmail.com
    TINNED-PRINTED-CIRCUIT-BOARD (PCB), on CEM3 support
    SILKSCREEN ( components mask ) of above PCB
    LEDadict noz-25's Avatar
    Feb 2013
    Montenegro
    71
    Very nice man and cheap!
    Custom life
    Thank you for your appreciation.
    Quote Originally Posted by noz-25 View Post
    Tinned PLCC32 adapter for parallel programmer , on FR4 support
    EXCELLENT, the link connecting me erroe brand. You can tell as the manufacturing method?.
    Greetings from Montevideo.
    Vera Guelmi
    Thanks a lot for your appreciation.
    I will upload also other pictures of pcb's released in the last period time.
    Maybe you suppose that the method used is toner transfer or UV ( photo ) but isn't.
    I have developed in last 15 years something cheaper than presented methods , and less " dangerous " (I mean working without dangerous chemicals)
    The method use a " sieve" as " screen " .......is not easy to describe you this method ( you need also a special ink for this procedure.
    If anybody without possibilities to make own pcb , are interested to have it , I could help them in the cheapest possible way.
    All the best to all of you,
    Mihai
    Quote Originally Posted by Guelmi Vera View Post
    Vera Guelmi
    Just released, PLCC32 adaptor (socket version) , tinned on FR4 support , can be found below.
    Tinned PCB with PLCC32- SMD
    Printed circuit board (with SMD components), double layer,on FR4 support
    Backside layer is "untouched" ( used as "screen" )
  1. What Could these I.C's be on this Circuit Board
    By Musgatz in forum Power Supplies
    Last Post: 11-16-2014, 07:10 PM
  2. SMPS AC to AC circuit
    By parvezsh in forum diysmps
    Last Post: 07-27-2013, 03:28 AM
  3. Replies: 8
    Last Post: 05-12-2013, 11:16 AM
  4. Replies: 9
    Last Post: 04-08-2013, 12:03 PM
  5. Loudness control - circuit!
    By radio in forum Pre Amps
    Last Post: 09-29-2012, 06:53 AM
