Page 1 of 19 12311 ... LastLast
Results 1 to 10 of 188
Thread: 1200W rms pro audio and simpe circut.
    Hİ THERE! I'M continuing the sharing something.
    Last edited by erhan739; 06-11-2010 at 10:35 PM. Reason: attachment resized and imaged
    you are pretty active, thanks for sharing. What did you use that monster for? How many speakers did you connect?
    a subwoofer i connected this monster and ı use subwoofer active crossover this monster's inputs ı can't stand this monster's sound
    More photos are appreciated, I will visit you some day to listen to it
    Can you post the active crossover you used? What response did you use?
    it's responces very terrible... ı used a jbl btx crossover my own edit. 40-120hz 12db oct gain 50hz boost and don't corrupted you can send fullrange at the same time to same out
    I think linkwitz is OK
    ı was opened active crossover toppic. When enough requests ı will publish quickly. but your speeck my interests i will send you a little thing if you want
    hi erhan
    greetings any schematic of this amplifier what output transistors have you used
    thanking you
    michelle
    the output transistors are writes on the circuit diagram. they are 2sc5200 2sa1943 and the driver transistors are mje340 350 and 2sc2500 2sa1943 again. you can give this circuit 2x80v up to.
    May 2010
    colombia
    25
    and the schematic?
