Results 1 to 10 of 13
Thread: 2kW Dual Rail Full Bridge SMPS
    Hi everyone. I have designed 2kW SMPS for my friend but i am stuck in designing feedback voltage regulation for -70V. I saw a circuit that it was sharing the feedback currents for dual rails. I have also read in book and it says the aim is to share feedback currents. I did it but i dont know whether it is correct or not.
    diysmps Senior Member vorezky04's Avatar
    Feb 2012
    Indonesia
    112
    Very Nice.. Have you the layout sir?
    I am from indonesia.
    I love peace
    Visit www.a-and-t-labs.com/‎ K6 amplifier power supply for an example of monitoring both rails.
    Jan 2012
    Germany
    35
    Your approach will work in principle. Maybe for dealing with the VFB-Signal , the following proposal is somewhat simpler.
    Figure 1 Voltage Regulation for Dual Rails
    By the way: I guess the values of the voltage divider R60,R61 and R51,R55 in your schematic are not correct. For propper operation the TL431 needs 2V5 at its Ref Input.
    Jan 2012
    Germany
    35
    Sorry, my schematic in figure 1is wrong. It is valid only for different positive rails. I was on the wrong planet.
    This is the final schematic for now.
    Jan 2012
    Germany
    35
    Check the Cathode voltage of the TL431 ! What is the switching frequency of your converter and what is the target crossover frequency of the compensator ?
    Feb 2012
    Indonesia
    112
    This is my design layout.
    I love peace
    Gate drive transformer PO585
    Quote Originally Posted by vorezky04 View Post
    I think if you can, modify this design with a gate drive transformer like the Pulse Electronics PO585, then the design will be more robust (less parts), PCB layout could be smaller and gain more isolation.I have an LTspice simulation of a fullbridge using ETD49 at about 2kW and more.PCB 180mm x 240mm and can be smaller.Your layout can improved
    Sample Schematic
    Quote Originally Posted by chas11 View Post
    Sample schematic, note this is a simulation(work in progress), not a working design ,don't construct supplied as a reference.FB.jpg
  1. 2kW Full Bridge SMPS Design
    By Fethiyeli in forum diysmps
    Last Post: 02-16-2014, 10:18 PM
  2. use a Computer SMPS to create a dual polarity DC supply ?
    By AndrewT in forum Switching Power Supplies Informations
    Last Post: 08-31-2013, 07:06 PM
  3. Help making a full bridge smps
    By grim3271 in forum diysmps
    Last Post: 03-14-2013, 04:43 PM
  4. Replies: 2
    Last Post: 03-01-2013, 02:56 PM
  5. Full bridge SMPS
    By Marko in forum diysmps
    Last Post: 05-03-2012, 08:24 PM
