Thread: Please, take a look at this TL494 power supply, is everything OK?
    Apr 2014
    Europe, Latvia
    15
    Hello!
    It happened, that I once bought 10 TL494 chips, hoping one day to make some SMPS. But unfortunately I'm unable to find a trustworthy schematic for it. The biggest problem is to find a circuit for a gate drive transformer part. So many variations, but almost none for driving mosfets.
    After looking through some hundred circuits and getting more and more confused I took these two for samples: AC-DC converter SG3525 Full Bridge.jpg not sure, but most likely from this site; and 15-48V SMPS Full.GIF from here.
    So I tried to combine them together, and this is the result: SMPS_494.GIF.
    Please, share your thoughts, criticism and suggestions about my creation.
    Thank you very much.
    Apr 2014
    Europe, Latvia
    15
    Yep................................
    Sad
    Your combined schematic should just work fine, Its impossible for any one to know if it will work 100% or not, but all seems OK to me, specially the 15-48V 16A design, because its 100% working design.
    And to make things clear, HYPEX uses almost the same techniques + TL494 in there SMPS. very close to the circuits you have just shown.
    So I think it would be a good idea to start your testings, and you will discover everything you are looking for.
    Apr 2014
    Europe, Latvia
    15
    OK, Microsim, thank you for the replay.
    I actually already made a PCB for the combined circuit SMPS_494_PCB.GIF, but it doesn't work- the 494 doesn't even want to oscillate. Could it be something to do with the open inputs of the second internal comparator (pins 15 + 16)?
    P.S. Some posts got lost somewhere ...
    See below circuit, and compare with it, this is used for an unregulated SMPS, so at lease it will guide you to know whats going on
    Apr 2014
    Europe, Latvia
    15
    Thanks for the samples, but they appear too small to see details.
    copy my TL494 schematics if you need half bridge I have just rebuilt it and it works straight. there is no regulation for the time being. you just need to adjust the turns for your core Ae and Bmax. I even tried one of your schematics you posted and fel into some issues: http://www.diysmps.com/forums/showth...+signal+issues if you need bootstrap startup you fill it inside here http://www.diysmps.com/forums/showth...ed-half-bridge
    Apr 2014
    Europe, Latvia
    15
    Thank you, zeus_threat. I'll try to "digest" those threads.
  1. Power Supply for X-Ray Tube
    By S0syk in forum diysmps
    Last Post: 07-30-2013, 12:45 PM
  2. 400A / 16V Regulated Power Supply
    By MAYDAYDEEJAY in forum Power Supplies
    Last Post: 02-06-2013, 11:41 PM
  3. Car Amplifier Power Supply
    By hot_but2cool in forum Power Supplies
    Last Post: 08-01-2012, 03:09 PM
  4. Preamp Power Supply
    By lupusaudio in forum Pre Amps
    Last Post: 04-29-2012, 05:30 PM
  5. Power Supply 13.8V
    By e.junior1 in forum Power Supplies
    Last Post: 08-19-2011, 02:28 PM
