Page 35 of 42 FirstFirst ... 5253334353637 ... LastLast
Results 341 to 350 of 419
Thread: 1000w smps based on LUDO3232
  1. #341
    Mar 2018
    126
    Turns for EE55 full bridge 230v = 19 turns (72Khz) B max at 245v 1450 guass
    Turns for EE65 full bridge 230v = 15 turns (72Khz) B max at 245 v 1450 guass
    Thank you for your answer, Mr. Silvio ... I use PFC with 350 volts on the primary voltage
  2. #342
    701
    Upik
    Please tell me core material if you know it as turns will differ with different cores. However for N87 material the number of turns are as follows.
    EE 65/32/27 Input voltage 350vdc Frequency 72 Khz approx rated transformer power 7.5KW Turns primary 14 (full bridge) B=1320g
    EE 55/28/21 Input voltage 350Vdc frequency 72 Khz approx rated transformer power 3Kw Turns primary 20 (full bridge) B= 1320g
    Never go beyond the rated transformer power in your design. However for the EE55 calculate a peak of 2800 watts and for the EE65 well this is good for a welding set at that power.
    You can assume the same turns for PC40 however this material is better.
    About your PFC circuit which one are you going to use, can you post the schematic?
  3. #343
    Mar 2018
    126
    I don't know what type of core I am using, I get ee65 and ee55 from used items. There is no clear information about the core used, I don't have a scheme for that.
  4. #344
    Mar 2018
    126
    I did not make my own pcb, I bought a pcb product that was ready to install the component
  5. #345
    701
    Quote Originally Posted by Upik View Post
    Well it looks very nice I hope everything goes well and works.
  6. #346
    Mar 2018
    126
    hi Mr.Silvio ,, do you have transformer calculation calculator software for full bridge topology, ??
  7. #347
    http://www.diysmps.com/forums/showth...-and-inductors
    The link labeled "ExcellentIT(7100).rar" is a program that can calculate for Push-Pull, Half-Bridge, and Full-Bridge. You can use 3 different types of secondary rectifier. Regulated or unregulated supply. The program has quite a few choices for ferrite cores, but you can add custom cores if you need to.
    The software is pretty close. I've done the math before by hand and it's quite good.
  8. #348
    701
    The software I have is like Blasphemy000 suggested
  9. #349
    Mar 2018
    126
    thanks for all, it turns out I already have it ,,
  10. #350
    Mar 2018
    126
  1. 1000W mosfet amplifers
    By MicrosiM in forum Mosfets
    Last Post: 09-23-2015, 11:22 AM
  2. Replies: 8
    Last Post: 11-17-2014, 01:53 PM
  3. IRS2092 2x500W/1000W BTL
    By b_force in forum Class D
    Last Post: 05-13-2013, 04:54 AM
  4. PiC based flyback SMPS
    By nigelwright in forum diysmps
    Last Post: 10-29-2012, 02:03 PM
  5. Quasar 1000w smps
    By tvicol in forum diysmps
    Last Post: 02-17-2011, 03:08 PM
