Page 31 of 37 FirstFirst ... 212930313233 ... LastLast
Results 301 to 310 of 369
Thread: 1000w smps based on LUDO3232
  1. #301
    Mar 2018
    126
    Berarti pcb yang saya buat sudah tepat mr.silvio
  2. #302
    646
    Quote Originally Posted by Upik View Post
    ????????????? English please
  3. #303
    Mar 2018
    126
    Is my pcb already proper mr.silvio ??
  4. #304
    646
    If you have the same pcb like in photo it may be ok except for the long traces to the gates. I suggest you try it out and see how it works.
  5. #305
    Mar 2018
    126
    For the trace gate driver I have updated, hopefully it is good ,, as in the following picture
    HB3000W V3.pdf
  6. #306
    646
    HB3000W V3.pdf
    It looks much better now as far as the gate drive traces are concerned. What kind of heatsink are you going to use on the switchers now? I believe you need some kind of angle aluminium and it better be a bit thick like 5mm or 6mm to get good dissipation and heat transfer
  7. #307
    Mar 2018
    126
    My pwm card is not working well, please check where its wrong.smp always experience protek, do not want to start, but if protection card not in use, smp can work
  8. #308
    Mar 2018
    126
    This is my protection card
    protect card.pdf
  9. #309
    646
    protect card.pdf
    It looks ok. I think if you have more current in the primary of EE65 transformer then you have to make less turns on the current transformer secondary Try 15-18 turns instead of 22turns. Otherwise it will start tripping the overload early.
  10. #310
    Mar 2018
    126
    I have tried 15 turns, but it still does not work properly
  1. 1000W mosfet amplifers
    Last Post: 09-23-2015, 11:22 AM
    Last Post: 11-17-2014, 01:53 PM
  3. IRS2092 2x500W/1000W BTL
    By b_force in forum Class D
    Last Post: 05-13-2013, 04:54 AM
  4. PiC based flyback SMPS
    Last Post: 10-29-2012, 02:03 PM
  5. Quasar 1000w smps
    By tvicol in forum diysmps
    Last Post: 02-17-2011, 03:08 PM
