Page 7 of 10 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 98
Thread: Audio smps 700w (IR2153)
  1. #61
    701
    @ Steppler
    Some more considerations
    1) input soft start missing+ bridging triac or relay missing
    2) input fuse missing
    3) safety ground capacitors missing 2 X 2.2nF X1KV
    4) grounding of the negative output terminal missing
    5) 1uF capacitor in parallel with output capacitor missing
    6) Grounding of the SMPS is non existent.
    If something happens and the primary of the transformer shorts out with the secondary you will see God prematurely.
  2. #62
    @ Silvio
    This is input power board:
    Among other things include softstart. 2s delay relay bridged resistors 40ohm 20W.
    Fuse to rear panel.
  3. #63
    701
    @Steppler
    That is much better. You showed a very basic schematic at first with a lot of things missing in it. By the way the pcbs you are making are very nice and looking professional.
    One other thing you should add is a 4.7nF capacitor from the high voltage ground to the negative ground of the secondary plus another capacitor 4.7nF from the negative of the secondary side to earth ground, this will protect both for EMI and also in the event of a short in the transformer windings (primary to secondary) it will find a path to earth ground and will trip the earth leak circuit breaker in the grid. One other choice is to ground the secondary negative terminal to chassis. If you have a double winding of say 30-0-30 then ground the center ground to earth ground. Take a look at my PDF file it can be downloaded on page 2 post #13. There I have a ground path which connects to chassis via the stand off pillars. Taking a general look you will see these capacitors I am mentioning, they are ceramic caps rated at 1kv.
    Did you get rid of the stray voltage?
  4. #64
    I changed the transistors to IRF740, I added the snubber. Result? .... 90V !!!!
    I disconnected experimentally output coils and 2 capacitors ..... increase to 95V.
    And transformer is very hot.
    I will try to add ground capacitors.
    The experiment continues ........ my name is Don Quijote ......
  5. #65
    701
    @ Steppler
    Did you wind the transformer yourself?
    This is very odd Iwound a lot of transformers and this issue never happened to me. As I said before without a scope you are blindfolded.
    The transformer getting very hot is not a good sign and it could be that something may be wrong with it. (There should be no gap in the center leg of the core for this topology (Half bridge) Try to change the IR2153 and see that it is genuine.
    Please check if the output diodes are in the right orientation as I am suspecting that you are having a voltage doubler effect.
    It could be also the case that the windings are in series aiding and doubling the voltage somehow. I am trying to figure out what may be wrong and these are only assumptions. The circuit is very basic and has been built by a lot of people but these mishaps have not been encountered before apart of a faulty chip or something that I mentioned before.
    Put a series 100w Lamp with your input wiring. You can attach it instead of the fuse. This will help in the event of something is wrong. The bulb should light up briefly and extinguish again on start up due to charging the main bulk and secondary caps. The filament should show no signs of glowing during operation of the smps without load.
    I suggest that you take a look at my Youtube video ( Winding small transformers for SMPS) This will help you out for a good safety transformer build Don Quijote LOL.
    Link https://www.youtube.com/watch?v=_K3ixhcTYFg&t=1s
    regards Silvio.
  6. #66
    I've just been glancing over this thread, but here is my thought.
    I'm assuming your input voltage is 220-240VAC. Rectified and filtered this would be around 340VDC, give or take a little bit. You are running a half-bridge topology, so the voltage being switched across the primary of your transformer will only be half of your input bus voltage, so about 170VDC. Now, given the details of your transformer, your turns ratio is 3.54:1, the maximum peak voltage coming from your transformer absolutely cannot be higher than 48 or so volts.
    Now, having said that, I can only think of two possibilities of what is going on here.
    1.) The primaries of your transformer accidentally got connected in parallel instead of in series. This would cause the output voltage to be doubled, but also would most likely cause the transformer core to saturate (or get really close to it) which would cause the output voltage to drop significantly under load and cause the transformer itself to get quite hot. This would also cause heating in the mosfets and could also cause them to fail.
    2.) The transformer is being driven as a flyback transformer. For example, if one of your mosfets isn't switching properly. These IR2153 chips tend to be quite fragile and I've seen many examples of the high-side driver just completely not working at all. If you've ever had a mosfet fail on this circuit, you should replace the IR2153 at the same time you replace the mosfets, because it is most likely failed also. In this case, if only your low-side mosfet is working, this could cause your transformer to saturate, run very hot, and due to the inductive flyback effect, cause a very high output voltage under no load conditions with a severe drop in voltage with any significant load applied.
    Your transformer only has a single secondary winding, so I'm not at all worried about the connections on that side. If the output diodes were reversed, it would either dead short the output (quickly killing the output diodes) or cause no output voltage at all.
    Without a scope you're just shooting off in the dark here, but those are my two ideas. Good luck and I like the professional board design.
    - Brad
  7. #67
    Hello I'm back.
    I measured transformer primary frequency ..... 92kHz !!!! That's weird !!! Rt=15k Ct=1n This is cca 50kHz. Puzzle ?????
  8. #68
    701
    Quote Originally Posted by steppler View Post
    Hello I'm back.
    Try to change the IR2153 and see if you have the same result, You can also change the timing resistor or capacitor until you get the right frequency
  9. #69
    This is my first post here, so - hello everyone!
    I have finished a 2 layer PCB layout for IR2153 project . The main difference is that I need only one secondary winding - 55V and as much Amps as possible
    It is based on the schematic from here:
    http://www.diysmps.com/forums/showth...er-IR2153-smps
    All designed to use parts from old ATX PSUs. Normally I would not bother and just buy a 500W PSU, but:
    -I need at least 4
    -I want to learn something!
    I am using an ERL-35 transformer. Various datasheets state that I can get 350-400W from it. With active cooling I hope I can go for 400-450W
    As I have no real experience with SMPS design, I would like to make sure that the PCB layout is at least acceptable.
    I want to go for 70...100kHz. At this moment I want to mention that I am not sure how to calculate the copper diameter for the secondary winding. If I use AWG25 (0.457 Amps), I need to use about 20 wires to handle ~9A? It would be very difficult to wind that.
    Back to the SMPS itself - I want the output ground to be isolated, because I will be connecting these SMPSs in series. Can I throw out C16?
    Here you can find the documentation:
    https://imgur.com/a/eLoqEG7
    PDF file:
    SMPS docu.pdf
    I will appreciate any suggestions and tips.
  10. #70
    701
    @Holgin
    As far as the layout of the pcb looks ok to me. Regarding C16 this can be omitted but there will no path for safety if the primary leaks with secondary windings and it will bring the smps secondary to mains potential.
    You will need to leave some margin space at the cheeks of the bobbin for safety around 2mm on each end on each winding.
    The wire you are using is fit for a switching frequency of 80Khz. I would suggest not going beyond this frequency as the switching losses will become quite significant.
    The current density of the copper wire is calculated at 6A/mm^2. Forced cooling is necessary for continuous use. You will need to add more copper for 100% duty cycle and current density will be more like 3A/mm^2. This will not fit however in your existing erl35 core and in case you will need a bigger core
    Volts per turn in this calculation is around 5.5v
    Aux winding 3 turns (1 wire 0.46) bringing up around 16v. A small resistor should be fitted in series according to the zener voltage (13v)
    You will be needing 28 turns total in the primary winding with 4 wires (0.46mm) twisted together or side by side see what fits best. This has to be divided in two, 14 being in the first winding then wind 3 layers of mylar tape. Wind secondary windings. 3 layers of mylar tape and finish with the last half of the primary. Try to fit windings in whole layers as partial layers will make the windings uneven and will build up a lot of leakage inductance.
    Secondary winding 10 + 10 windings ( 7 wires 0.46 side by side or twisted see what fits best). this will bring two windings with a center tap so that you can use a double diode in the output. the current will also be divided between the two windings, each will carry around 4.5 amps.
    The transformer rated power is 683 watts and the total power absorbed at 9 amps will be 413w. This is assumed with a core material of N87 by epcos. The peak voltage will be 56v with no load at 230vac input. This however will drop 10 to 15% with load as the smps is not regulated.
    I suggest taking a look at my video on youtube called winding small transformers for smps.
    link https://www.youtube.com/watch?v=_K3ixhcTYFg&t=1s
    Good luck Regards Silvio
  1. Replies: 28
    Last Post: 04-24-2019, 07:39 PM
  2. 700W AMPLİFİER!
    By Sierra in forum Class AB
    Last Post: 07-21-2017, 08:14 AM
  3. Another IR2153 smps
    By borysgo2 in forum diysmps
    Last Post: 04-29-2017, 10:07 AM
  4. monoblock 700W rms/2Ω
    By ultra in forum Car Audio
    Last Post: 05-29-2013, 08:06 PM
  5. Building my first AC/DC 700w SMPS
    By Adonix in forum diysmps
    Last Post: 07-20-2011, 09:24 AM
