Results 1 to 10 of 12
Thread: How does this overpower/short circuit protection circuit works?
    Hi all,
    All is in the title, I've joint the schematic.
    How to implement short circuit protection if the driving transformer have no extra winding for this function (only 3 pins in input) and without using pins 15 and 16 of the IC?
    Many thanks
    It looks like it is using flux imbalance or leakage to detect an over-current condition that energizes a733 which in turn kicks on c945 latching up the two transistors and lifting pin 4 above maximum dtc voltage?
    Quote Originally Posted by Easyamp View Post
    .... lifting pin 4 above maximum dtc voltage?
    Yes, the goal is to pull pin 4 up. But how ?
    What is the roles of diode and capacitor in the base of a733?
    When there's a short circuit the voltage at the capacitor increases or decreases?
    Why we don't invert the diode and connect it's cathode to the base of the npn transistor c945?
    diysmps Senior Member Silvio's Avatar
    394
    Maybe you can opt for a current transformer in the center of the half bridge, Then feed the rectified output of the current trafo to control the pulse width via the soft start pin. This will become a current fold back control. One other option is to use the over current opamp on the TL494 to control the output current via a sense resistor on the output. I do not see any particular reason why not using it. What about output voltage regulation using pin 1 and 2? What kind of PSU are you making after all?
    1- you can opt for a current transformer
    2- use the over current opamp on the TL494
    3- What kind of PSU are you making after all?
    1- I want the simplest solution.
    2- you mean pins 15 and 16?
    3- I'm moding a PC ATX PS to get regulated voltage using pins 1 and 2 and constant current using pins 15 and 16 and a sense resistor.
    Because of the constant current option we don't need a short circuit protection, but I want to add this function in case of a short in the sense resistor, who knows !
    How to check if the short circuit protection is working without burning the power supply?
    394
    Follow this circuit it works I tried it you will have variable voltage and variable current. You can make fixed resistors instead of pots if you do not want it variable. Just omit the 4.7uf cap tied to pin 3
    you can also follow this link http://320volt.com/en/akim-voltaj-ay...nagi-modifiye/
    You could build a simple latch and monitor the current on the primary ground return(s)
    any transistors should work, although some tweaking maybe required.
    OK thanks a lot for the link and the circuits.
    I've already do the mods as shown in 320V circuit and it works, but if I fix the current for a given load and change to other one the current change a little !!
    394
    by how much does it changes? It could be that the sense resistor is getting hot and changing value. What current limit do you need?
    Yes, perhaps it's due to the sense resistor !!
    The change is small, about 100 mA.
    I need a range of 0-10A
  1. IR2153 smps with short circuit protection.
    By norazmi in forum diysmps
    Last Post: 03-31-2017, 06:40 AM
  2. SG3525 Driver Circuit
    Last Post: 08-05-2015, 07:32 PM
  3. What Could these I.C's be on this Circuit Board
    By Musgatz in forum Power Supplies
    Last Post: 11-16-2014, 07:10 PM
  4. SMPS AC to AC circuit
    By parvezsh in forum diysmps
    Last Post: 07-27-2013, 03:28 AM
  5. active short-circuit breaker for your amplifiers
    Last Post: 10-11-2010, 09:25 PM
