Results 1 to 7 of 7
Thread: Testing circuits
    Testing circuits
    How do you guys test your high current circuits like smps? I gather that smps circuits for high current applications cannot be tested on a breadboard. How do you guys test your design before putting it together in a permanent board? TIA.
    562
    Hello Bergaustein, Testing high current circuits will only get results by building prototypes and fixing bugs that are encountered during the tests. It could be the pcb design. EMI, and design frequency and also choice of topology all play an important part. It is only with previous experiences some things can be avoided. The rest will have to be found out when testing the prototype.
    I hope that helps
    Hello Silvio, do you know any material that I can read regarding proper PCB layout for smps? something that is being implemented in the industry.
    562
    Hi, I am sorry to say I never came across these reference books except when reading some data sheets and application notes regarding integrated circuits (ICs) that show how to place components around them. There are EU regulations that can be found on line that state clearances regarding to voltages handled by the circuits involved. As for myself I made a lot of observations regarding ATX psu and noticed the clearances they used. About procedures well the shorter the path the better and avoiding high current paths to be away from the small signal ones or at least when crossing them will be as short as possible and at right angles to minimize coupling to them.
    Copenhagen, Denmark
    78
    This goes for "small" devices as well .
    Silvio. If one only have a scope and some Fluke multimeters, how to test for emc ? Some ground knowledge is perfect, but my fantacy has not yet brought me to where I can test for EMC and such.
    562
    Quote Originally Posted by Malmir View Post
    EMI = Electro Magnetic interference EMC = Electro Magnetic Compatibility
    A Very Simple and rather strait forward Test .
    Get a radio near your project and tune to a weak channel, if the channel you are tuned to is interrupted with noise you will know that you have EMI. If it will not be disturbed from a meter away than you will be ok. At least its a simple and affordable test that you can make.
    Measuring EMI is rather a bit complex in a way and need special equipment like spectrum analyzer and some other things to receive magnetic waves generated. You will also need to measure the intensity and these have to comply with standards. I believe if you do some reserch on google you might find something to read about the subject.
    Try to google this ( How to measure EMI ) You will find answers for sure
    Copenhagen, Denmark
    78
    Using a radio is cheating but yes that should Work. As I said my fantacy was not into this .
  1. Testing old torroids for transformer use?
    By TroelsM in forum diysmps
    Last Post: 05-11-2017, 01:21 PM
  2. Replies: 6
    Last Post: 07-01-2015, 12:28 PM
  3. smps schematic drawn for welding, now testing.
    By kees54 in forum Switching Power Supplies Informations
    Last Post: 09-25-2014, 11:33 AM
  4. Replies: 18
    Last Post: 01-29-2014, 10:57 AM
  5. i look for comparing circuits ...
    By nknb in forum Custom Projects
    Last Post: 11-05-2012, 07:06 AM
