Thread: What is frequency range of speaker
    Hello
    What is freq range of speaker in sound bass and treble
    here is the schematic
    How this job is done
    here is white boards
    580
    Quote Originally Posted by TBEEYY View Post
    Hello
    A normal speaker can handle a lot of frequencies usually in the region from 50 hz to around 20 Khz. This also depend on the type of speaker used as larger speakers handle bass notes better then their counter smaller speakers, the latter however can handle high frequencies better than lower ones. This is the main reason that usually there will be 3 speakers in a speaker box as each speaker can handle a range of frequencies suited to its size and construction. The crossover takes care to distribute the right frequency range for each speaker.
    The human ear cannot hear more than 20Khz and this will be when you are still young, As you grow older it will be more or less up to 15Khz at the most.
    Some further reading can be found on this link https://www.teachmeaudio.com/mixing/...udio-spectrum/
    Hello
    How the speaker box are designed of which wood
    580
    Stop asking silly questions You can look for your answers on youtube and the internet.
    Hello
    ok which wood ply board are used
  1. What is this speaker name
    By TBEEYY in forum Site Announcements
    Last Post: 10-08-2018, 08:40 AM
  2. Wide input range
    By vortex in forum Switching Power Supplies Informations
    Last Post: 11-17-2016, 02:42 PM
  3. speaker spares
    By mkubawat in forum Pro Audio Speakers
    Last Post: 06-01-2016, 06:26 AM
  4. Low efficiency and short output voltage range
    By dragondgold in forum diysmps
    Last Post: 12-18-2014, 05:03 PM
  5. Replies: 0
    Last Post: 03-07-2011, 04:37 PM
