Results 1 to 7 of 7
Thread: IR2153 Class D amp
    586
    Lightbulb IR2153 Class D amp
    Anyone heard about it? should we give a try? schematic? yea i have it with single supply N-ch mosfet
    100
    i found schematic from this link https://320volt.com/ir2153-class-d-amfi-devresi-400w/
    interesting, but I'm more interested in class AB than class D
    100
    Quote Originally Posted by res_smps View Post
    at least I know ir2153 can be a class d amplifier , I tried simulation but I can't make it better
    maybe Norazmi has a better design
    Interesting ! you can do even frequency modulation by varying the IR frequency with a transistor from pin 3 to GND. The output filter passes the low frequencies more and HF less.
    Class D is interesting too, you can get big power easily and the sound quality is still very good !
    This is good enough for class D. Can I get from you the IR2153, irf640 and lm311 ltspice symbols ?
    100
    Quote Originally Posted by expressel View Post
    attached, please check
    Thanks, res_smps
    468
    anyone who has tested this version?
