Thread: SMPS and class D amps
    PLEASE be kind, I'm new to this forum and electronics in general and I know the following question is very basic, but I need some help. I need to power two classD boards requiring +/-36v and putting out 200w a piece. I have found an SMPS that puts out the correct voltage and handles 500w. The problem is, there is only one output terminal from the SMPS. Can I double up they wires in each terminal and be safe. Or how should I wire this?
    734
    Quote Originally Posted by fingersg View Post
    Is this smps regulated?
    for double voltage you have to put another winding on the transformer.
    You will also need to have a full bridge rectifier at the output and also capacitance on both outputs
    Take a look here to get an idea what it involves
    https://www.youtube.com/watch?v=_K3ixhcTYFg&t=1s
    734
    You can also buy 2 smaller power supplies and connect them in series
    This is the SMPS I'm referencing.
    https://www.ebay.com/itm/500W-35V-Am...YAAOSwX9FZL7x5
    How do you set up multiple power supplies in series? BTW, thank you for your time.
    734
    As far as I can see the Power supply listed already has a dual output voltage of 35-0-35 (+/-35v). There is nothing that you should do except connect it to the amplifier.
    But I want to run two amps off of that one power supply. Each amp is 200watts. Do I need to double the wires in each hole of the terminal? Three wires+,o,-, going to each amplifier.
    734
    All you have to do is insert 2 wires in each hole of the connecting block. 2 wires for positive, 2 wires for ground and 2 wires for negative. take one wire of each to each amplifier so that each amp has 3 wires +35/0/-35.
    Thank you, that is what I was hoping.
  1. SMPS for Class-D amp.
    By plasma in forum Power Supplies
    Last Post: 12-20-2013, 04:22 PM
  2. How are made Powersoft Digam amps?
    By joseph r in forum Class D
    Last Post: 05-01-2012, 07:46 PM
