At 60Khz EE65 can deliver 5500w or more. You will need thicker wire in transformer better output diodes and better switching mosfets or IGBTs that can handle 40amps or more. You need to re design the pcb for heavier current in the output. You will need more input and output capacitance.
With 5500w Is it capable with HB mr.silvio topology ,, ?? with little change in mosfet and diode., I have 6 capacitor 850uf / 400v on primer. That's what i have. If indeed without changing many original components from schematic, I want to build it. because my Amplifier power is now class d4k5. and pair of d2kneo.seppose both need voltage and current is big enough.
