First successful test of my 1KW PFC.
Setup looks bad, But this is how it looks first time!
Setup Information:-
Topology:- CCM
Input Voltage:- 107VAC
Output Voltage (DC):- 382VDC
Output Current (DC):- 2.9 AMP
*Voltage Drop at 1000W Load is around 3 Volts.
* Current Drawn from 107 V AC line is 10.4 AMP (AC) _ PFC Loaded
* Using IGBT
* Special costume Inductor used, 200C rating
* IGBT Tempreture after 15 Minutes 58C with FAN.
I noticed that the output diode affects the PFC performance, it heats like hell and causing the voltage to drop very quickly Until I found the correct one.
Upcoming tests will be shown, when I have AC source of 90VAC + more tests at Higher Loads!
Thanks for reading. :UP:
however, Load BURNED after 42 Minutes of continuous operation
[video=youtube;z6VwjmiZsxI]http://www.youtube.com/watch?v=z6VwjmiZsxI[/video]
Setup Information:-
Topology:- CCM
* Using IGBT
