The recomended bias for the amp is 20-50mA per output pair,but i haven´te noticed any diference between higher and lower value so it is set on 20mA when it reaches working temperature. This amp should be set for bias in a few steps:bias will be at higher value when the amp is cold so it should be monitored on the sors resistor that gives the highest value of voltage drop. Place the leads of voltmeter with crocodile clamps on that resistor and follow the value of voltage. Using Ohm´s law U=R x I = (0,47 x 0,02) V adjust the bias untill it stops droping down. Than you can begin to use this amp at full power. If in any case you can not reach 20mA bias,just replace 470R trim. with 1k trim. and you will be able to reach much more. It is atentionally put that way for safety of burning output transistors because it is mentioned that a lot of beginers will do this amp for them self.
Enjoj!
