Winding EE16 High Frequency Transformer
mcmsat
I have to admit my difficulties whenever high frequency transformers are involved in my project!
Please I want those who know their way with ferrite winding to assist me with this EE16 winding.
Though the power is not needed for high precision but core saturation will not be tolerated.
Below are the parameters for the SMPS
AC Input Min = 85V
AC Input Max = 265V
AC Input Frequency = 50Hz
PWM Controller IC = NCP1200
OScilation Fequency = 100KHz
Output Voltage = 14VDC
Output (I) continous = 800mA
Duty cycle Max = 87%
Core = EE16 See the Attached picture for the trafo parameters
The power does not need isolation. The optocoupler is easier for me to use but it is not used for isolation.
Below is the schematic diagram of the SMPS.
I suggest you contact Starichok51 in the tread CALCULATION PROGRAMS FOR TRANSFORMERS AND INDUCTORS
Regards, Silvio
Chris_C
Hi. :)
I would think that multiple strands of small gauge wire, like Litz would work. Or what I do is twist 4 or 5 smaller gauge like 36 or 32 lightly, just to hold together to avoid skin effect at 100KHz. Parallel multiple strains of 'strains' for higher current.
This photo is of one of my first SMPS projects.....that worked:D. I am new to SMPS, and my next challenge awaits.:adoration: Here, I used the strain of strains method for the small toroid, Epcos N87, 115KHz, 3+3 || 8+8, 51.26mmSq
Would foil be an option for your transfo?
Hi. :)
This photo is of one of my first SMPS projects.....that worked:D. I am new to SMPS, and my next challenge awaits.:adoration: Here, I used the strain of strains method for the small toroid, Epcos N87, 115KHz, 3+3 || 8+8, 51.26m mmSq
Please specify what currents are you talking of in the primary and secondary windings. Please also specify the duty cycle of the smps as there is a difference in a power supply delivering full current all the time then another having say 50% duty.
Knowing this we can work out what is the best wire or foil to use.
I suggest you read the blog post Making Litz wire at home so that you can understand more about the subject.
mcmsat
OK thanks Pals, I have use the Excel sheet Transformer Calculator and it solved my problems. I am using it for high frequency transformer winding and it's not dissappointed me. Thanks.
mcmsat
Hello Silvio, please can you send me a link where I can buy those foils used in high frequency transformer winding which are normally insulated with a yellow adhesive tape?
@mcmsat
Hi I do not think you can buy readily made insulated copper foil tape, however you can purchase copper foil which is available in various thicknesses. The ones usually used is 0.1mm, 0.2mm and 0.3mm. These sheets of copper can be cut to size with a normal scissors.
Insulation mylar tape can be stuck on one or both sides. However the mylar tape being a bit thin it is advisable to put 2 layers of tape on each strip of copper.
Mylar tape is a special tape used for transformer winding. This tape can withstand high temperature up to around 150 degrees Celsius and not loosing its properties in any way. Mylar tape exist in various widths and can be purchased on E-Bay or Aliexpress. Copper foil sheet also can be purchased on E-Bay and here are a few links. You can look further for other thicknesses and sizes.
https://www.ebay.co.uk/itm/99-9-Pur...026258?hash=item1ec891f012:g:ZZoAAOSwy3NZYypu
https://www.ebay.co.uk/itm/30mm-Wid...310761&hash=item44100ff1ea:g:oYEAAOSwrhhaRGko
https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20180203091253&SearchText=tawny+tape
https://www.aliexpress.com/item/1pc...d49d-4f22-a276-df13750bd3a4&priceBeautifyAB=0
mcmsat
Thanks Silvio, I now understand. It's because they are displayed without the myler tape that made me not to recognize them on Aliexpress. I buy all my components from Aliexpress.
Thanks Again.
