Results 1 to 1 of 1
Thread: Design of Current mode boost converter using MCP1630
    I was trying to design a current mode boost converter in CCM using a MCP1630 from microchip with the following design requirements:
    *Vinmin=2.7V (minimum input voltage).
    *Vinmax=4.2V (maximum input voltage).
    *Vout=5V (Output voltage).
    *Iout=5A (Maximum output current).
    *RL=5 Ohm (load resistor Vout/Iout).
    To meet these design specifications, I have calculated the components and they are as follow:
    *Dmin=0.16 (Minimum duty cycle)
    *Dmax=0.46 (Maximum duty cycle)
    *L=5uH (Inductor value)
    *Ipeak=2.2A (Peak current)
    *C=200uF (Output capacitor)
    *Fc=8kH (Crossover frequency).
    The sense resistor is selected to be Rs=0.36 ohm, because the maximum current sense signal for MCP1630 is 0.9V (for Ipeak=2.2A Vsense=Ipeak*Rs=0.36*2.2=0.8v, we let 0.1V as a margin).
    For the feedback control I have sellected a type 2 amplifier, I have used K-factor method to calculate the components, so the found values are given bellow:
    *Divider network: Rup=Rlow=10k
    *Refrence voltage Vref=2.5V
    *C1=2.5nF
    *C2=15.6pF
    *R2=100k
    I have attached the circuit designed in proteus 8 for clarifications
    My question is:
    Unfortunatly, when I simulated my circuit, I never get 5V at the output, instead I get 3.94 and the duty cycle approaches 90% and I don't know what is the reason for that failure. Please try to figure out where I have mistaken!!
  1. Boost Converter Sputter Mode? Huh?
    By The_Ed in forum diysmps
    Last Post: 10-07-2018, 04:54 PM
  2. BOOST converter with 34063 IC
    By noz-25 in forum diysmps
    Last Post: 11-12-2015, 12:54 PM
  3. Replies: 8
    Last Post: 11-26-2012, 08:04 PM
  4. DC Boost converter
    By tonigau in forum diysmps
    Last Post: 02-06-2012, 11:51 PM
  5. 4-10kw boost converter/pfc
    By staska in forum diysmps
    Last Post: 01-14-2012, 09:55 AM
