Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 45
Thread: 700W AMPLİFİER!
    Quote Originally Posted by Sierra View Post
    I forgot to attach the ZIP File!!!
    hi Sierra,
    FYI, the file was corrupt ?
    i will try to make this one
    hello buddy,
    how about the four bias diode,mounted on heatsink
    Thumbs up Files
    Quote Originally Posted by qmara_just View Post
    hi Sierra,
    Yes, at first I only forgot to attach.
    See last post from Jakub_G, All files now complete
    Thank you
    Thanks for all interests and assistances. I know ı'm not alone this way.
    Technical Specs
    Quote Originally Posted by JAKUB_G View Post
    Output power: 680W/2R, 450W/4R, 260W/8R Measured on 550VA transformer with 2x54V AC non-loaded
    Everything you can find below:-
    That sounds good, Please would you tel us the specifications of this amplifier?
    Output of amplifier with frequency response? max power
    Another 700W amplifier!!
    Power Supply is +-80VDC
    Enjoy!
    Some pictures and full files in ZIP format!
    hi Sierra,
    How is it sounds impression compare to super leach amp? can you share us video on your test?
    Thanks and more power.
    regards,
    rosa
    Thank you
    Ok, i've downloaded the file.
    thank's alot.
    regards.
    Quote Originally Posted by engel View Post
    hello buddy,
    These diodes are substituted by one NPN transistor as you can see in schematic diagram
    http://zosilnovace.eu/700W/700Wsch.png
    Quote Originally Posted by Corvett View Post
    freq response: 10 - 180 000Hz/-3dB
    Max power 700W/2Ohm
    Slew rate: 35V/us
    TDH+N: <0,07%
    IMD: <0,04%
    Quote Originally Posted by rosa View Post
    hi Sierra,
    regards,
    rosa
    Superamp is more dynamic in basses, but it has a disadvantage-the power dissipation on the power transistors is higher, than in the case of classic parallel output stage.
    http://zosilnovaace.eu/
    Power Amplifiers
    jacob_g
    thank you,
    absolutely that was one of the transistor mounted on heat sink,one way of eliminating bias diode as of the original designer prof. Leach amp sec. stage
    http://users.ece.gatech.edu/mleach/lowtim/2ndstage.html
  1. Stk 4048 specİal edİtİon amplİfİer
    By erhan739 in forum Chip Amps
    Last Post: 09-30-2014, 06:53 PM
  2. Replies: 28
    Last Post: 10-07-2013, 12:34 PM
