Results 1 to 2 of 2
Thread: Troubleshoot OLD SMPS 200W
    Hi
    My first post here. I have for repair one old SMPS 150-200W which had broken caps and PWR trans in LIVE side.
    Now it has two trafo 5V/15A ,12V/5A +15V/1,5A -15/1A. it has a LM1723 I think as ref. with an SCR and a "Secret" pottet board with, I think, control circuit.
    It do not really startup, pulls .7A @ 90V AC and the SCR and PWR trans gets hot !! So I do not get full mains on it (yet).
    Then the output voltages is not right yet but If I pull out the SCR The output voltages aspire and look right but it makes alot buzzing noise.
    I do not have any info or schematic on it. So any good ideas are most wellcome.
    Here is some pict.
    Check power devices, then make sure that the chip has the supply needed to power it up.
    Also, check those capacitors at the primary side
  1. Topology for 50-200W SMPS for amplifier
    By TroelsM in forum diysmps
    Last Post: 07-07-2017, 09:24 AM
  2. Looking for help to troubleshoot a solar inverter
    By bocasvalenti in forum Switching Power Supplies Informations
    Last Post: 07-27-2013, 11:35 PM
  3. Replies: 2
    Last Post: 04-11-2013, 05:42 PM
  4. New Project - 200W, HV SMPS, need advice
    By tartan5 in forum diysmps
    Last Post: 01-13-2013, 01:29 PM
  5. Leach-200W High End Amplifier
    By MicrosiM in forum Class AB
    Last Post: 02-21-2011, 10:55 PM
