Results 1 to 6 of 6
Thread: Standard gap for ferrite for flyback converter
  1. #1
    diysmps Member
    May 2019
    4
    1
    The paragraph that i marked yellow color. The author mention about that:
    From the calculate: lgap = 17 mils why the author select standard gap for this core 67mils with an AL of 100mH/1000T?
    Reference : Power Supply Cookbook, Second Edition By Marty Brown
  2. #2
    852
    Quote Originally Posted by nhatspkt View Post
    From what I am assuming is that not everybody has the means of making a gap in a standard non gap core. From what I am thinking is that he is preferring to use a standard gapped core with the minimum gap available at the time of writing the book.
    However there is a means that one can put a spacer between the cores to create the gap. The gap will be on the three legs however the spacer thickness has to be half of the said dimension. This way there will be also some EMI generated from the ends of the core as the gap is present on the three legs instead of the middle leg only.
  3. #3
    diysmps Member
    May 2019
    4
    1
    Can you give me some advice how to calculate flyback tranformer and select Bmax, D ?
  4. #4
    852
    [QUOTE=nhatspkt;16244]Can you give me some advice how to calculate flyback tranformer and select Bmax, D ?[/LinQUOTE]
    Here is some software that you can download and this will calculate everything for you, You have various software programs for flyback, half and full bridge etc. Select the one you need.
    Link https://www.diysmps.com/forums/showt...er+design+tool
  5. #5
    diysmps Member
    May 2019
    4
    1
    Hi Silvio,
    A few year ago, I have been used this tool for calculating. But I'm feeling that the result for calculate is not correct. Would you like to tell me some book that mention about calculating transformer for SMPS?
    Best regards,
    NHAT DAO
  6. #6
    diysmps Senior Member res_smps's Avatar
    Oct 2012
    bandung, indonesia
    147
    please check AN-4137 fairchild
  1. Replies: 1
    Last Post: 02-24-2017, 04:31 AM
  2. Replies: 0
    Last Post: 07-18-2016, 04:01 AM
  3. SMPS using PIC, flyback converter.
    By nigelwright in forum diysmps
    Last Post: 10-13-2012, 09:33 PM
  4. Forward /Flyback Converter Control Theory
    By ricky4u in forum Power Supplies
    Last Post: 07-26-2012, 03:58 PM
  5. Standard stereo 3 band tone control circuit
    By hferreira in forum Hobby Circuits
    Last Post: 06-30-2011, 01:10 PM
