Results 1 to 2 of 2
Thread: 400w current-mode boost UC3845
  1. #1
    hi
    i design this circuit and build it.under no load condition input is 15 and output is 36 without problem.but when i connetct a 6 ohm load out put voltage drop to about 14.5v and output current about 2.4amps.
    inductors are self made 31turns/2.5mm gap/er28(pc40 material)55uh
    under no load condition when i connetct input its take about 4-5 seconds to output set 36 volts.
    do you know what is problem?
  2. #2
    853
    Have you tried a larger output capacitor? For the output you need to put a light load for the output voltage to settle quicker.
  1. Design of Current mode boost converter using MCP1630
    By kirous in forum Switching Power Supplies Informations
    Last Post: 08-23-2019, 07:28 PM
  2. Boost Converter Sputter Mode? Huh?
    By The_Ed in forum diysmps
    Last Post: 10-07-2018, 04:54 PM
  3. Replies: 13
    Last Post: 04-01-2015, 08:16 PM
  4. GX400 - 400W Audio Amplifier
    By donpetru in forum Solid State
    Last Post: 08-31-2014, 10:22 AM
  5. DIY Electronical Ballast 400W HQI
    By plasma in forum Power Supplies
    Last Post: 11-02-2013, 05:27 PM
Tags for this Thread
