Thread: LED Driver IC 51LP
    Confused LED Driver IC 51LP
    Hi All,
    This is my 1st post and I apologize if it is in a wrong section. Please feel free to delete or move to the right section.
    I have a 9W LED bulb and it has a transistor like SOT92 IC marked as 51LP and beneath it marking F48, which is blown up.
    I want to repair this and coudln't find the part nor a datasheet to see if possible to find a substitue.
    Attached are few shots.
    829
    I am not sure about this but it could be TL751LP. This is a low dropout voltage regulator
    here is the link for the datasheet https://www.alldatasheet.com/datashe...I/TL751LP.html
    Hi Master Silvio,
    Many thanks for your reply and the link.
    I got the pdf and as per page 2 the "ORDERING INFORMATION" table and the "TOP-SIDE MARKING" column, it does not include any matching markings for "51LP F48" as per the listed/below:
    TL750L05C
    50L05C
    51L05C
    750L05C
    TL750L05C
    50L08C
    750L08C
    TL751L10C
    50L10C
    51L10C
    750L10C
    50L12C
    51L12C
    750L12C
    Since you are a master and this driver circuitry confuses me, then I need to ask isn't this circuit a buck converter so it needs a pwm ic?
    I managed to find a datasheet but its in chinese and hope it helps.
    http://www.radioradar.net/en/datashe...2-ETC.pdf.html
    Much appreciated.
    829
    There exist a 3 legged chip such as the TOP family like TOP221 which is used as a flyback buck converter. I am sorry to say that a chip with that name 51LP I never heard of. I guess you will be better off buying a small PSU that can power your leds. They are very cheap from E-Bay or Aliexpress.
    Hi Silivio,
    Thank you for your reply.
    I was given a reply with this link by "JFJ" from a wellknown repair site's forum:
    https://www.olx.ro/oferta/kp1051-51l...tml#55cc21ad46
    and this with datasheet in english:
    http://www.kiwiinst.com/product_deta...3=24&id=132###
    It's the same IC.
    Hope it helps others.
  1. Need help for opto driver
    By mihaiu16 in forum diysmps
    Last Post: 02-16-2020, 10:21 AM
  2. What topology is this and how does the driver work?
    By bogdan2011 in forum General Electronics
    Last Post: 08-01-2019, 06:32 AM
  3. SG3525 Driver Circuit
    Last Post: 08-05-2015, 07:32 PM
  4. modifying an LED driver
    By domi7 in forum diysmps
    Last Post: 01-22-2015, 09:25 PM
  5. modifying an LED driver
    By domi7 in forum Switching Power Supplies Informations
    Last Post: 01-22-2015, 09:22 PM
