Results 1 to 6 of 6
Thread: 2 basic question about half bridge smps.
    Hi everyone, please do me a favor.
    1. So far I found on the internet, these are the most common configuration of half bridge.
    I want to know what are the advantage (or disadvantage) of each configuration or which one I should use in which situation.
    2. In the case of audio smps, I found most of the time people use separate winding for 12V/15V or other output along with the main output winding, while in general purpose smps, they use tapping instead of separate winding. What is the advantage (or disadvantage) of separate winding over tapping?
    Can you please give me some basic idea about these?
    Thanks in advance
    Sukdeb.
    834
    @sbdada09
    Please note that when using 2 bulk capacitors in the input the capacitance across the 320v is half. As a rule of thumb we use 1uf per watt of power across the 320v rail.
    Fig 1 shows a basic arrangement with 2 divider capacitors but the DC blocking capacitor is omitted
    Advantage Using less parts making the pcb more economical
    Disadvantage 1 If in the event of failure of one of the mosfets the full charge of the capacitor will drain with a very high current.
    Disadvantage 2 The value of capacitance across the 320vdc rail is half
    Fig 2 shows the classical way of making a half bridge with 2 divider capacitors and a DC blocking capacitor to eliminate the danger from the previous arrangement of fig 1.
    Disadvantage 1 the DC blocking capacitor takes a lot of beating and has to be of good quality such as film etc. The voltage rating must be higher than that of the half bridge itself.
    Disadvantage 2 the rail capacitance is half.
    Fig 3 Shows another classical arrangement but this time using only one bulk capacitor and only one divider capacitor. This is the most economical way of producing a low cost pcb and also space saving
    Advantage The capacitor across the rail holds the full capacitance
    Disadvantage The DC blocking capacitor takes a lot of beating and has to be of a very good quality as all the current has to pass through it.
    Fig 4 This shows another arrangement this time using one bulk capacitor and 2 voltage dividing capacitors (C2 and C3) C4 is usually used in resonant applications where the capacitor resonates with the leakage inductance of the transformer.
    Advantage 1 The bulk capacitor holds its full capacitance.
    Advantage 2 the divider caps C2 and C3 will work at 50% duty and the capacitance value in them reflects to be double.
    Fig 5 is the same as above regarding advantages this time the resonant capacitor is omitted. This configuration is uses mainly in hard switched and high power applications.
    Regarding windings.
    Normally in high power applications due to the fact that the high current secondary windings being made with multiple strands it would not be so convenient to introduce tappings, however separate windings are chosen so that a single or bifilar winding can be easily done. Auxiliary winding are normally used to supply fans and pre-amps.
    In smaller smps then due to the winding wire is made of a single strand then it will be more convenient to use tappings from the same windings.
    Thank you Mr. Silvio for your valuable information, these will help me a lot.
    I'm little bit confused though, sorry for that. As you said, C4 in figure 4 resonates with the leakage inductance. Same configuration also used in figure 2 and 3 (C3). Doesn't it also convert the converter into resonant mode?
    834
    Yes it can resonate but it depend on the value and the switching frequency. However in the cases shown the capacitor is there to block DC
    Ok, it's clear now. Thank you again Mr. Silvio .
    480
    thanks all for this topic it was helpfull
  1. Replies: 7
    Last Post: 06-29-2018, 12:29 PM
  2. Half Bridge vs Full bridge SMPS
    By robson132 in forum diysmps
    Last Post: 01-28-2018, 05:34 PM
  3. 350W Half-Bridge SMPS with PFC
    By dragondgold in forum diysmps
    Last Post: 07-17-2015, 10:12 AM
  4. Half bridge SMPS based on ETD 44
    By Khaderah in forum diysmps
    Last Post: 10-01-2012, 08:29 AM
  5. Flyback vs Half Bridge question
    By rcbuck in forum diysmps
    Last Post: 03-12-2012, 06:16 AM
