Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 41
Thread: My new custom built 10' subwoofer
    diysmps Senior Member Lira's Avatar
    Mar 2011
    São Paulo, Brazil
    127
    Hi, I´m assembling a speaker, if you have some time, wait a little, i´ll post the pictures step by step of the whole process, from centering the coil to glue the sorround, including how do I center the coil exactly, I think it might help you repairing yours.
    Best Regards
    Lira
    Studying electronic engineering
    Fanatic for audio
    Crazy for biiiiig speakers
    thanking you Lira
    I try my best
    can you explain about contents which is have in your glue(scotch mix) because it is not available in India.
    Mar 2011
    São Paulo, Brazil
    127
    I think ARALDITE is available in india you can use this one for the coil on the spyder and on the cone
    and this one for glue the metal parts
    Here is the link with everything you need
    http://www.huntsman.com/advanced_mat...fm?pageID=5909
    http://www.huntsman.com/advanced_mat...fm?pageID=5908
    Fanatic for audio
    thanks Lira
    ya ARALDITE is available in india but rework is not possible after using araldite if we want replace only voice coil. if possible please tell me. very difficult to replace only to voice coil in branded speaker and stuff the rest is put into use again.Have any idea .....
    Mar 2011
    São Paulo, Brazil
    127
    It's a controversy, if repair this with a glue that it's not tough enough, it will fail soon, but will preserve the original parts, if you use any kind of epoxy glue, you won't be able to repair it again.
    What would i do in your case: First disassemble the whole speaker an than take note of everything, the cone hardness, the voice coil (Number of turns layers, kind of wire, kind of material etc...) and try to copy, from the scratch, you will get a lot better result doing this. I tried to repair many many speakers, but the repaired speakers is not as good as the ones i use new material to repair, even the speaker has flat wire on the coil, you can use round wire, the difference is not that big, considering you repairing and old coil versus a new one. If the original coil is made of aluminum, you can change to Kapton or fiber and have a more eficient speaker.
    In any of cases you will have to re-measure the Thielle-Small parameters to ensure all the parameters of the speaker.
    Hope this helps
    Best Regards
    Lira
    Fanatic for audio
    Lira.
    JBL Used the special flat wires, they used the flat wire coils in all of there professional speakers.
    Once there is a cut into that it will be impossible to solder it.
    JBL is robust speakers indeed.
    Mar 2011
    São Paulo, Brazil
    127
    Quote Originally Posted by MicrosiM View Post
    Lira.
    I know, if you can use it, if it is in good conditions, you must use it. I was saying about, because there is some cases that the coil is deformed or old(with not correct impedance), in that case, you can try using it, but if it keeps blowing i sugest rebuild everything! Perhaps i didn't understand de problem well, sorry.
    I have some speakers to repair, they use flat aluminum coil, very hard to solder, i didn't repaired already because of that problems.
    My idea was to try to copy the coil in round wire to use-it in case of unrepairable original coil.
    Fanatic for audio
    hi microsim soldring is possible
    Mar 2011
    São Paulo, Brazil
    127
    Lira
    Here some pictures from speaker I will repair soon.
    This speaker fails very quick, I dont like it
    I centered one woofer today succesfully using about 4 layes of OhP transparency paper, the only difficulty part was to remove the OhP paper from the coil, because it was too tight. But the speaker is now on pink noise for 72 hours. I,ll edit e videos and the pictures and post here soon.
    Thanks for the attention!
    Fanatic for audio
    how to test a speaker with pink noise & where i find it
  1. Subwoofer processor i need
    By gchim in forum Pre Amps
    Last Post: 04-04-2019, 12:58 AM
  2. Car power amp for subwoofer 180W into 8ohm
    By JAKUB_G in forum Car Audio
    Last Post: 06-03-2016, 08:16 AM
