Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: My new custom built 10' subwoofer
    This is so intresting thank you lira for sharing
    diysmps Senior Member Lira's Avatar
    Mar 2011
    São Paulo, Brazil
    127
    Quote Originally Posted by mkubawat View Post
    how to test a speaker with pink noise & where i find it
    Its simple, first you need a reliable pink noise sourcehttp://www.burninwave.com/, such a software with a good sound card( like maudio or similar, cheap audio card wont work) or an audio processor like behringer utracurve pro (DEQ2496) (This one is what i use), a good condenser mic, plugged in the sound card and a software for spectrum analize like TrueRTA http://www.trueaudio.com/rta_abt1.htm, to power the speaker, you need a amplifier with a maximum 0,002THD 100W RMS.
    You have to equalize the pink noise output to be as flat as possible in all range of frequencies with the mic that you are using. than you can test the speaker.
    Later i put the pink noise with 70% of the power of the amplifier to soften the speaker (I know, it will be a bit loud) and leave for 48hours, than i make all the tests again.
    That's it. if you have any further questions I'm here to help
    Best Regards
    Studying electronic engineering
    Fanatic for audio
    Crazy for biiiiig speakers
    Thumbs up
    Thanks LİRA, It's a good explanation
    hi Lira
    sorry but i don't understand, What role will the mic and where to put
    Mar 2011
    São Paulo, Brazil
    127
    Well, it's good you record the pink noise on any device such as a good mp3 recorder on 320kbps, and use this as a external pink noise source, them plug the mp3 player on the line in of the soundcard and see if the pink noise of your source is accurate. Be sure to disable any equalizer or sound enhancement devices on the mp3 player to have the pink noise flat. Once you have your source of pink noise ready to go, plug off the soundcard and plug in on an amplifier. Now you put the mic on the mic input of the soundcard, (You can use a mixer between the soundcard and the mic but you will have to plug the mixer on the line in of the soundcard), and start testing. the mic must be at least 20cm of the speaker. If you want you can use a sealed box to make this test, than you can see the curve of frequency of your speaker on the trueRTA. Its a bit tricky to get it working for the first time and get the right parameters, you have to watch for the volume to not saturate the sound of the speaker, testing different volumes, you will get the idea how your speaker can operate in differents powers.
    Best Regards
    Fanatic for audio
    Thanks Lira
    anybody know about scratch resistant mat black paint for commercial speaker box & where to find in india
  8. #28
    hi
    any one know ,what is the benefit of reverse fitted woofer
  9. #29
    Mar 2011
    São Paulo, Brazil
    127
    You mean put the woofer reverse on the box like this?
    Or this?
    Fanatic for audio
  10. #30
    like a first picture
    also post about phase system when play many speakers , woofer (when all speaker are at a place)
  1. Subwoofer processor i need
    By gchim in forum Pre Amps
    Last Post: 04-04-2019, 12:58 AM
  2. Car power amp for subwoofer 180W into 8ohm
    By JAKUB_G in forum Car Audio
    Last Post: 06-03-2016, 08:16 AM
