Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
Thread: First attempt of TD Class on Leco Amplifier Module
    Feb 2018
    Trinidad west indies
    1
    Quote Originally Posted by fitzroy View Post
    class td sunfire amplifier whats the different to me the same
    below schematic of lab gruppen fp14000
    Feb 2018
    1
    down converter circuit
    Feb 2018
    1
    Cool
    in going through the white paper by bob carver
    years ago on the switching down converter i searched for the schematic for the sunfire amplifier then i heard about class td same down converter circuit little changes which use a switching power supply a blind man can see both circuits are the same one uses hcpl2400 and the other hcpl2411 same ic who found this design first bob carver or lab gruppen?the heart of the class td and the sunfire amp is the switching down converter circuit or the buck boost circuit.without it it just an ordinary class a or a class ab amplifier. which will need massive heat sink and lot lot more output transistors. who is this design acreditted to??????????
    Feb 2018
    1
    years ago on the switching down converter i searched for the schematic for the sunfire amplifier then i heard about class td same down converter circuit little changes which use a switching power supply a blind man can see both circuits are the same one uses hcpl2400 and the other hcpl2611 same ic who found this design first bob carver or lab gruppen?the heart of the class td and the sunfire amp is the switching down converter circuit or the buck boost circuit.without it it just an ordinary class a or a class ab amplifier. which will need massive heat sink and lot lot more output transistors. who is this design acreditted to??????????
    white paper
    any one have you fpq 10000 smps PWM drive schematic ???
    Feb 2018
    1
    Quote Originally Posted by khalsa View Post
    only got this page
    need this schematic
    Feb 2018
    1
    20190406_122625.jpg negative pwmpatd module
    Feb 2018
    1
    add 39k resistor from pin 1 to pin 3 of negative pwmpatd circuit i posted
    Feb 2018
    1
    20190406_160305.jpg negative pwm circuit
  1. High End 100W Class AB Amplifier
    By Sierra in forum Class AB
    Last Post: 04-26-2012, 10:19 AM
  2. Ab class amplifier
    Last Post: 04-23-2011, 03:21 PM
  3. Universal 50W amp module.
    By JAKUB_G in forum Class AB
    Last Post: 03-27-2011, 10:58 PM
  4. class AB Amplifier using LME49810
    Last Post: 03-27-2011, 10:46 PM
