Page 50 of 50 FirstFirst ... 2040484950
Results 491 to 496 of 496
Thread: 2 kwts discreet class d need help
  1. #491
    492
    hi all . have a look at katrinos amp it looks amazing . have fun all
    http://www.diyaudio.com/forums/attac..._v.2_final.pdf
    http://www.diyaudio.com/forums/class...ml#post4963498
  2. #492
    hi norazmi
    your pcb doesent match schematic you have posted.i have made the amp with irf540n its working fine they are heating a lot
    setting the preset only the negative side fet heats a lot.should i change gate resisrer 22 to 47 ohm.
  3. #493
    492
    please post photos of your pcb project
  4. #494
    Hi Stewin
    why you do not answer in www.diyaudio.com ?
    can i ask you here?
  5. #495
    492
    sorry i was away busy with errands but now i can spare sometime. by the way which topic did you raise the question sir?
  6. #496
    492
    hello everyone
    i am building the below amp based on this thread , but i will put two daughter boards, one for the protection board and the other for the amp ucd drive.
    i will change the protection to manoj aud600 protection cause it was the only effecient and effective i have ever came across so far.
    The other daughter board for ucd protection will be able to change from discreet to ic version or even sigma delta mode , by just changing the board.
    opinions and ideas are highly welcomed and appreciated
    photos are below , i have failed to upload here
    >>> https://www.diyaudio.com/forums/clas...st6259993.html <<<
