Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: d3k high power class D
    Thanks..
    Can work with a simple smps.
    Sep 2012
    176
    Yes sir
    I use smps at all
    Hello acca.
    A few questions.
    Can be used instead of mosfet igbt for use only subwoofer amplifier, decreasing the frequency to 70 kHz. I can use 2 parallel igt
    Can be set to full bridge using mosfet.
    Sorry for translate.
    Thanks.
    hola yo lo hice funciona bien pero se escucha el clok y no le pude poner 1n lo mas cercano es 102 se te ocurre algo
    492
    hi acca any photos of your project??
    492
    hi acca any updates??
    i,ve tried this and mine doesn,t work....sorry for my bad english
    Hi acca.
    I made class d amp with tl494 and ir2104
    It don't have feedback.
    The output of tl494 have noise
    I made two schematics and boss of them have noise(like play 3khz in midrange)
    I attached schematic photos.
  1. High power amplifier 1600watts@ 2 ohms
    Last Post: 06-21-2017, 12:52 AM
  2. Replies: 2
    Last Post: 04-11-2013, 05:42 PM
  3. High End 100W Class AB Amplifier
    By Sierra in forum Class AB
    Last Post: 04-26-2012, 10:19 AM
