Page 46 of 46 FirstFirst ... 1636444546
Results 451 to 460 of 460
Thread: 1000w smps based on LUDO3232
  1. #451
    I want to make SMPS for my Arduino based voltmeter.
    I have TNY267 and other components but I want to make SMPS Transformer and its winding.
    Please let me know.
  2. #452
    864
    Quote Originally Posted by imahmed67 View Post
    Please let me know.
    Here you have a link and you find all the details you want. If you want a lower voltage other than 12v just change the zener diode to the required voltage.
    http://www.theorycircuit.com/simple-smps-circuit/
  3. #453
    Hello friends , can somebody tell me , is this wave form ok ? and if its not , what should i do ? f is 70Khz, wire of the transformer ETD49 N87smps1.jpgsmps.jpg is solid wire 2mm, i was unable to find thin wire to make strands , with no load everything is more or less cold, only for testing i'm using SPW20N60S fet's, and output diodes are BY229X, will be finished with FDH44N50 in primary and RURP3060 in output .
  4. #454
    864
    @ Marshall. The wave forms look good I guess these are the low and high side being read together.
  5. #455
    Yes, low and high side at the same time, also I don’t know how to check for a dead time, i think this is all ok, output voltage +/-75V, exact voltage that i need , totally symmetrical on the both sides. On the beginning i had problem with protect, it triggered very quick at startup, but I followed and read all your advices , I change resistors on current sense stage with 33R and 22R, also i change 330p to 0.1uf on 393, also i add 10uf capacitor on soft start for little bit longer start, that is pretty much about it, anyway thanks for your positive advices and replies, I’m continuing to follow you Mr. Silvio !
  6. #456
    864
    To check the dead time you need to take out the cursors and put the waves on top of each other. You will notice that one wave has a shorter pulse width than the other. You need to measure that difference with your oscilloscope and you will find the dead time. Adjust dead time for around 1uS.
  7. #457
    I had made a SMPS 1000w which was already posted in this thread. Now i am facing a problem when connect to Audio Amplifier . Some Humming noise is coming. Same Amplifier i have tested with Transformer it is OK, But when connect to SMPS i am getting some noise. Please guide me what could be fault.
    Thanks and Happy New Year
    S Das
  8. #458
    864
    Quote Originally Posted by mituadas View Post
    S Das
    You may probably having a ground loop. Make a star ground on the amplifier chassis and ground all your ground points to it. That is the preamp the the power supply ground and the amplifier ground. These must be tied to this point. This should solve all your problems.
    The ground I am mentioning is the centre ground.
    Happy new year also to you and your family.
  9. #459
    Hello. Dear Silvio, you can send me the original PCB file to my email address so that I can change it a little to meet my requirements. I will be very grateful for the service rendered. My email alikangelok@mail.ru with Respect to You and your creativity
  10. #460
    Please help me for preparing transformer
  1. 1000W mosfet amplifers
    Last Post: 09-23-2015, 11:22 AM
    Last Post: 11-17-2014, 01:53 PM
  3. IRS2092 2x500W/1000W BTL
    By b_force in forum Class D
    Last Post: 05-13-2013, 04:54 AM
  4. PiC based flyback SMPS
    Last Post: 10-29-2012, 02:03 PM
  5. Quasar 1000w smps
    By tvicol in forum diysmps
    Last Post: 02-17-2011, 03:08 PM
