Page 3 of 20 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 200
Thread: Group Buy 2KW Class-H Amplifier
    how is possible o/p 2kw with only 6 pair of transistors with single pcb ? please explain If don't mind.
    What is size of heat sink
    Quote Originally Posted by mkubawat View Post
    Yes 2000W is not a Joke, But I got 1800W @ 2 Ohms since my transformer is 40-0-40 x2
    If you rais voltage to 55-0-55 x2 you will get 2KW for sure.
    Whats the relation between single sidded PCB and 2KW?
    12 Transistors are good for 1800W amplifier but HEAT also is a lot at 1800W, Heat sink is 37CM x12 CM *in my application*
    And What about output stage? Can you tell me which transistors are there?
    http://zosilnovaace.eu/
    Power Amplifiers
    Output devices
    Quote Originally Posted by JAKUB_G View Post
    @ Jakub_G, transistors used is 2SA1943 and 2SC5200, Also you can use other transistors like MJL21196, MJL21194, but compensation is required when you change output devices
    Just six pairs of output transistors for 2kW? That must be some kind of joke. If you use efficient transistors like MJL21195/96 six pairs is not enough too. Can you calculate the current which flows over one transistor in full power into 2 ohms? Output devices are surely out of SOA....
    Power Amplifiers
    @ Jakub_G
    I also agree with you..............
  8. #28
    Jan 2011
    SF & Las Vegas - USA
    10
    The 1800 Watts is impossible with a 40-0-40 toroid or even 50-0-50. This amp is H class. it requires at least +120 +80 -0- -80 -120 .... +high +low grnd -low -high
    This amp also requires a control board and a pre-amp with housekeeping circuits and ALSO a Input board and Power Supply board
    Minimum power 85-50-0-50-85 per board.
    WITH dual high-low power you get enough current to increase output to at least 1.5K - but nothing matters without a control pcb AND pre-amp pcb
  9. #29
    Jan 2011
    10
    Quote Originally Posted by AutoclassA View Post
    This is opposite of required I think.
  10. #30
    Quote Originally Posted by silverprl1 View Post
    ooops, I am sorry I was talking not rectified, AC!!
    I had 53V RMS at 2 Ohms from that transformer witch is
    +120 -0- -120 +60 -0- -60
    Also you are free to buy a PCB or not!
    This is an amplifier for audio
  1. Replies: 34
    Last Post: 10-30-2019, 10:58 AM
  2. High End 100W Class AB Amplifier
    By Sierra in forum Class AB
    Last Post: 04-26-2012, 10:19 AM
  3. Ab class amplifier
    Last Post: 04-23-2011, 03:21 PM
  4. class AB Amplifier using LME49810
    By JAKUB_G in forum Class AB
    Last Post: 03-27-2011, 10:46 PM
