ludo3232
New video + Hi res PDF of parts side.. all values are readable...
PCB of Protection card comming soon ...
[video=youtube;9i4EQG2_j8A]http://www.youtube.com/watch?v=9i4EQG2_j8A[/video]
  • SMPS Imp.pdf
ludo3232
Protection Board Schematics and PCB
  • prot brd PCB.pdf
  • prot brd.pdf
  • prot brd Cm.pdf
engel
smps master's
thanks for sharing this nice project
and sg3525 is good choice not hard to find
does the core used by most pc psu rated in 400w is the one called etd49?
how about the core can be found in an old pc monitor?and some old crt tv's is this useful for this project?
smps master's
We can do something regarding those cores, I think they are ER39 or ER33 ones, they still can make 500W at least
If you have succeeded into splitting the cores without crashing them, show some pictures here, I might be able to help!
Dont forget that the PCB is Designed for ETD49!
oh. it is a big trouble for me. i cant find it in Vietnam and on mouser ,farnell or digikey.
I have a friend in European but in UK and distrelec not available in UK.what a pity
Now i find someone in Germany to buy it for me.
Any other transformer with 20VAC 3 ~ 5VA output will do the JOB, even an external one!
rumsas
ludo,
what is efficiency and switching frequency of that SMPS? why don't you use filtering inductor's at smps output ?
Transformer
@Khron
N27 core with 22 Turns at primary of current sense transformer
@Rumsas
230Vac Main
75Khz
Voltage with no load : 110V
4A load : 106V
8A load : 102V
12A load : 97V
Load are 424W - 816W - 1164W
Primary winding are 10 x 0.1mm wire
Secondary 15 x 0.1
Hope that helps
Inductors, they should improve performance, but ludo got a nice results!, but they can be added
I think he needs 15uh on -26 core material
Khron
Thanks, MicrosiM, but that was a bit vague...
The "primary" of the current transformer should be that thick wire jumper, right?
So the current transformer "secondary" (that goes to the protection board) will need 22 turns around a... T50-sized ferrite toroid core?
100% correct
a Thick wire goes Through the core is the wire used to feed the ETD49
and the 22 Turns goes to the protection card
engel
microism
the core i found in old tv and pc monitor are bigger than one found in pc psu,
will post picture soon
terminaterx300
i have just finished my job. redrawing the pcb of ver2.1 :D
p/s just little modifying for looking. i think it is okie R#:
