I don't see why this should not work. The small capacitor if fitted between the secondary and primary winding should be removed from one of the two power supplies. This will prevent any ground loops entering the high voltage end of the power supply. The reason is that they can react with each other and burn. The protection from this capacior will still be effected as only one cap from one of the supplies is removed.
