badboy_6120
I want to share my experience with watt meter....
On my SMPS i have 3 capaciters of 680uf.. And the averege power factor is about 0.71
But i will advice you to buy a wattmeter it will cost 20-30 dollars
Thank you
I will
I loaded the SMPS for about 40 minutes with 500W and here's the temperature results:
Mosfets body >> 66'C
Output Diodes body >> 73'C
Input bridge >> 78'C
Transformer cores >> 61'C
All temperatures above unit is Celsius
View attachment 5394 View attachment 5395
I think you have a very nice results fom first shot.
Improving the effeciency of the SMPS is another thing, also reaching above 87% of effeciency (at Full Load) is not an easy task. otherwise you go with PFC.
Good luck
Good luck
Oh, congratulations, this is only the beginning, I slept the whole bucket:anonymous:. Place the GDT, the PWM controller will remain intact. Sorry for my English.I got a dead SG3525, IR2110, 1n4148 fast diodes feeding gates of mosfets
If you are using IRFP460 as power devices, its normal to fail at 1500W.
Your goal at the beginning was to drive an audio amplifier, and now you are pushing the SMPS beyond an audio amplifier use, I wonder why you are looking for that amount of power?
Remember, reaching that amount of power requires proper made transformer with litz wire, High quality PCB, Good PCB layout, etc...
So for an audio amplifier use, I think you are OK with your results, beside I am sure that your layout and your transformer (maybe) has the minimum safety regulations.
Good luck
you didn't mention anything about input current a fuse???
Thank you
I was just curious how much power can I get(because as I said in the first place I wanted to drive my 2*500W sub amplifiers and 2*200W Music amplifiers)
I thought maybe I could deliver that much power with just this SMPS
Ok I won't go beyond 1000W
Thank you
I bring you two pictures from smps while loading 730W (50 minutes until now)
************The input ac current is now 2.9A rms************
the temp of mosfets are : 100"c (becuase of the size of heatsink)
the temp of output diodes are : 60"c
the temp of input bridge is : 60"c
the temp of transformer is : about 62"C
View attachment 5398 View attachment 5399
I placed two piece of papers between the two sides of cores to make a little gap and rapped the transformer with mylar tape to prevent any movement ( this way my output voltage is more stable and mosfets heats less and I think it's because it prevents transformer to saturates???)
Making air gap will change the inductance of you transformer, and leakage inductance also.
So that piece of paper may get you into the proper inductance @ your running Freq.
Your test result looks really nice, I am glad that you have this success rate from first time.
I advice you to make a NEW pcb layout, if you want to make this as full project
I always design my pcbs with "Express pcb" program
I will post one of my design and you say that it's ok to draw this pcb in it or not
Express PCB, is good for basic PCB job, I respect that software, but for sure I recommend something like EAGLE as minimum, if you plan to share your work as standard project.
You can download it and check it out, and view some tutorials on you tube, it will make you a pro PCB designer in 2 days.
I will try to help as much as I can in your Layout.
Good luck
