All right, U1 - 161B (324/2). U2 - 160V (80+80) +lose, + Efficiency
I'm not sure I understand your point. If second winding is rated for lower voltage/higher current then the wire should have more cross-section area to carry extra current (assuming we use same current density for both winding).
put a real volt, label - AC.View attachment 5428
240v*1.41 - 0.7v*2 (to account voltage drop on rectifiers) = 337v. half bridge configuration will drive primary winding with +-337/2 = +- 168.5 v (minus voltage drop on Rds or Vcesat).That's exactly my point
More current means more wire diameter
but now I calculated the maximum current of primary winding for 1400W output and I got about 16.7A
and output with 8A on each rail reach its maximum at 11.3A
So maybe this is right!!!!
Where did you find this? Are you sure it fits HB?
I think the right way to calculate primary current for square wave HB, neglecting voltage drop on switches, diodes, magnetizing current, DT is:
I = Po / Efficiency / (Vdc / 2)
Thanks, it looks like authors assume efficiency of 80% and DutyCycle = 0.8.
Absolutely right.All that ^^^^ implies we have use inductors after the rectifier ridge and continuous current in the inductor.
What do you think is the reason for transformer over heating?
We've figured out that primary winding current is close to current in secondaries. So you sohuld use thicker wire for primary winding.I red somewhere that the safe frequency for 0.25mm wire(copper) is above 100Khz
I think my winding thickness is not enough???
Primary >> 22x0.25mm
secondary >> 32x0.25mm
The left one is Secondary homemade litz: outer diameter is about 2 mm
The right one is Primary homemade litz: outer diameter is about 1.5 mm
Thank you for your help and answers
I will try above tips and report the results
Not a problem, but you must connect all of the windings right. To do that you can use either RLC meter or an oscilloscope and some HF signal source (you need to find where "start" of every winding).I wind all the transformer winding wire in one direction but I do not remember if I start and end windings at witch pin
could this cause any problem?
