here is the modification for Stewin, remove R4 and D2, R38 and D13 and last D4 and D15. You can avoid them and the reason aux supply heats because of them. Without that components amp still working and its for startup only. if u put them at high rails, will cause aux transistor blown within 10 secs.
make same aux 12-13 v supply from negative rails, there will be 2 aux supply for each. and one supply connect to D3 and D10, and another one supply connect to D14 and D19.
So take a look at output stage u need to input 1uf caps 250v parallel with em, see my drawing for full bridge version. and make dummy load at output to ground about 3.3k 3 watts resistor. U also can put zobel network at output 15 ohm + 100nf caps to get nice high freq output, this is stated with iraudump 7D which they use zobel network too.
Change D5, D11, D16 and D20 with shcottky diode, 1N5819, SB160 or Bat64. Its very important to improve THD, or if u dont have it, u can put uf4004 @ mur120, but shcottky is better. If u want protection OCP which short circuit protection take it from ucd2.5 from RU, they work and i`ve tested it. i can give u OVP and UVP + OTP from iraudump 7D can be place together with this ucd.
draw it back, let me see if u get correct schematic.
regards.
