Etd34
@Sekhar
ETD34 Ae is 0.97 CM2
Primary voltage 150V
I assume you are using 3C90, if other let me know, thats 1200B MAX
witch gives 32 Turns for Primary. @ 100KHZ
Secondary for +- 40VDC 8.5 Turns - 8.5 Turns
When you make your first proto type, you may need to do some slight modifications +- 1 Turn.
ETD34 will give you 400W at 100KHz, ETD39 700W @100Khz. and more power for music play!
If you are going to show the results of your work here, I guarantee that you will make a good SMPS. here you will get REAL help.
Hope that helps :UP:
