Car SMPS DC-DC SG3524 and SG3525 complete with schematic and PCB ready.
here you go, here i put smps application for car amplifier. include schematic and PCB. Credit goes to mnicolau and already build & tested. its for small and medium power range, if u want more power i can post version 2.0 can drive 4 mosfet. Will post some picture of complete and running smps with this model.
Azmi.
  • SMPS DC-DC Compacta v1.1.pdf
Winding details, core use is EI33 or EI35 from old psu.
Primary - 2 x 2 turns awg 28(40 strands) stranded wire.
Secondary - 6 x 6 turns awg 28 (16 strands) wire.
First wind 2 turn primary from "c" to "e". (Clockwise)
Second wind 2 turn primary from "e" to "d".(anticlockwise)
for secondary.
1. wind 6 turn from "q" to "r"(Clockwise)
2. wind 6 turn from "r" to "s"(anticlockwise)
- u can do wind first all for Primary and follow by all secondary for simple winding.
PCB dimension:
Main board will be : 100 x 72 [mm]
Driver: (SG3525): 46 x 41 [mm]
Driver: (SG3524): 45 x 40 [mm]
its very compact pcb :D .
some picture and video of finish smps here :D
[video]http://www.youtube.com/v/JFYdiyrk8vc[/video]
aronne
If I use a frequency of 60khz what's the values of the R and C for the snubber filter?
wally7856
I think the transformer is running close to 60khz.
sg3524
pins 6 and 7
6.8K, 1nF
130khz / 2 = 65khz at transformer
So you would use his values on the schematic, or fine tune them with a scope.
aronne
Hi wally7856. Thanks for reply,
I'll do the changes wich you have suggested me, I have sg3525
sartono
Hi All, I'm interested on building this Car SMPS. If supply voltage is 24Volt DC, what component should I change ?
Thank for reply..
