How to calculate ferrite transformer core size for a push-pull SMPS?
Dimonis
problem here is the shops that stock cores here have mostly chinese made ones and very
little information i am trying to make a simple gate transformer for my smps
Can suggest cores from an old ATX power supply , you can take EE19 core ( PC40 material), or better - the ring core used for the common mode choke . (something like N30 and T38 materials )
Here I tried different kinds , all work well , but the best is on the 10000 permability ring and wound with Litz wire. (the one on the right)
marmis
Do you know what music power factor means?((@
A constant power supply of 200W can handle up to 500-700W music power.:D
Customer requirement calls for 2 x 350W stereo amp powering 2 speakers of 350 W each. Are you suggesting that for these conditions we actually need only 2 x 250 W constant power supply? Is SMPS = 50% of music power a rule of thumb?
michelle
Core p material
Hello
greetings this is the core that i want to use P MATERIAL ZP44916TC as you can see its being used in smps made in china
whats the advantage of this core over ETD and EE CORES
warm regards
michelle
michelle
Colour of core
THIS IS THE CORE this smps manufacturer is using
warm regards
michelle
