I need a +/- 22Vdc to run 8 TDA2052. I was thinking about using a TL494.
... and starting DIY! The transformer ist tricky... 100µm 2 layer PCB, I hope so!
Thats right! Or buffer, for peak loads. You would like listen to music? Audio signals are very complex? No problem if amplifier is directly connected to the batteries, here the SMPS stepped up the power, but not instantely. If you like realy dirty sounds then, well, 1000µF will be enough...
Don´t care, the charging and decharging is managed by the 3525, but I know 10000µF/63V are expensive! The cost for one prototype will be 500€!
I have a new design for the SMPS:
- Flyback topologie,
- ETD54,
- 8200µF IN; 2200µF OUT.
I spend all my time for the output filter (toroid Kool Mu core)... More to come next weekend...
You need to find other guys who like to built this SMPS to reduce the price of the PCB: -50% for 10 pieces. But also, good capacitors costs a lot of money, dont forget this! You need low ESR high temperature ones! Its a professional developement: two sided PCB with 100µm copper layers.
The transformers are standard: EPCOS, FERROXCUBE, N67 core, copper wire about lets say 50€...
The price of the SMPS is given by: the capacitors, the PCB, but sorry if you turn on this you reduce the performance and the quality!
I have a mercedes and i am happy with the sound of the audio in this car. I´m not interested into building a car amplifier, but it is a nice challenge. My choice would be a high quality tube amplifier then the car audio speakers are very good ones. Less power but more quality!
... here the binary datas: you can modified what you want, you need EAGLE.
Don´t forget, you have to do ERC... and if you want some modifications, placement and so on...
