yes it should work. . Sry guys maybe slowly reply because i`m still not well yet FLU infection.
In order to make some of you happy, here’s the schematic of my 1kw smps.
This is the same based combination of IR2110 and SG3525 but, has lots improvements like a linear short circuit protection, better response of output transients, high output peak current and voltage regulated. Specially designed for audio applications.
Enjoy!
hi bettecher you have drawn schema with error i have circled below
Thank you Norazmi, I was sick like you, but I’m ok now. Hope you are better!nice psu u have there, i like it small . I like your trace too . Nice setup and nice result too
Have you built this SMPS? works well?
Hi! bettecher,
Any plans on sharing your PCB for DIY? Have you replaced the other version with the relay? Though I have not constructed an SMPS, I thought the use of an added relay on board adds up to better protection of the whole circuit.
Regards!
Norazmi, i want ask to you. How to increase frequency of IR2153?
which a value of component to change?
If first F=70 khz to 100Khz?
Please help me.
hi bettecher pls post a schema with a soft start relay included
