How in the world did you manage to spend over 2000 euros on this power supply.
2000 euros still low amount for SMPS development, I spent more than 7000 Euros between parts and equipment's
Good luck
Above 2000 Euros just for PCB design and PCB realisation.
Components are separately.
>>> when you pushed to the limit " 5kwt " did the etd 59 over heat ?In all videos, JUST ETD59, the only core that I use.
At 5 Kw, the core will get warm without fan blowing air on it.
Is Half Bridge resonant mode topology, at 70 Khz
I used LitzWire.
IGBT's , still in testing for decide exact ones, usually I used IRG4PC50
Secondary is winded in last tests for +/- 125Vdc in idle.
Yes, you can use!
But be sure the code is finishing with HGTG30N60A4D, and made exclusive by FAIRCHILD.
