Maxter 3600
irvynejay
engel sorry but i was wrong upon reviewing the schematic its not crest it's only DPU3k6
To achieve the full power of the amp voltage should be 70/152 -/+ and the power output trannies should be MJL4281a or higher
irvynejay
nope its DPU 3k6 design
load limit at 4 r only non bridgeable
shot attach
engel
maxter output looks like ca18 output ca18 modern leach breed,
and maxter front looks like qsc's front
  • qsc.zip
  • crest1.zip
mkubawat
Here is clear layout of step driver
irvynejay
ne5532 responce
scope reading ne5532 is bad when high rail triggers
irvynejay
ne5532 replace tlo82 ,72
Change Ne5532 to TL082 or 72 cracking is gone when high rail triggers
michelle
maxter great sounding amp tested in 2 ohms load real loud and punchy
thanking you
michelle
michelle
chestap your driver pcb
hi chestap
greetings driver pcb is over power pcb almost done how do you bias this amplifier what is voltage over emmiter resistances please can you help out
Thanking you
Michelle
