In the attached image You will see the circuit that I want to start with...My idea is to put some strong transistors like BU508 (few in parallell with balancing resistors 0,1 ohms for equalizing the currents through transistors) and one or two in darlington connection with BU to get current gain through BU's, and I think that for current of 15A through transistors I should put about 10uF/400Vdc non electrolitic caps in both sides instead of 0,22uF/400Vdc (I will put 3x3,3uF/275Vac in parallell in every half of circuitry).But I still do not know what core to put for power of 2,5 kW for example.Should I increase the working frequency which is now something above 22kHz, and how to do that?I have cores of Ae of 4.5cm2, I think that is enough for that power.And finally how to calculate windings for that tranformer?
