smps is it possible to increase dc output
irvynejay
Hello I just want to ask if this is possible to improvise or increase output of this smps
its rated 110-220 47-64khz 12v 15 ampere
its using 2sc2625 power output and KA7500B SMPS Controller driver
pls see photos
michelle
smps 2500 watt
Hi Irvynejay
greetings sir this smps 2500 watt easy to diy then clone it
warm regards
michelle
mikecarel
Yes it can, for as long as your trafo can handle your computed windings. Refer to norazmi trends about TL494. KA7500 is the same controller as TL494, it only differs in pin assigment but similar applications.
irvynejay
ok ty sir mikecarel,,but norazmi used mosfet this smps use BTJ
Michelle yes easy to clone but how there are no value
Irvy, my smps with TL494 also use BJT, read it, its about the same. Yes u can have more output voltage by adjust feedback and re-winding your trafo :D
