It's OKwill i have any serious problem with my transformer??
i mean with the way i winded it..
Hi, does it work in 127v? If not, what can i do to use in 127v or 110v?
Thanks all.
Yes,when rectify outputs and then use in series.hi acca...
as you said i can't conect bipolar transistors in parallel...
i have an idea...
i will make two separated smps on the same board...
each smps will drive a power transformer(erl35) and i will conect the secondaries of the transformers in series in order to achieve 600-700 watt 2x60 volt...
will it work?
Ma sta kazesUse schematics from post #44. R16 is CFL torus. Best Uni SMPS i ever build.
